I've got my hands on a new to me Grizzly 1019z 14" bandsaw that uses a 98" blade. The blade that came with it isn't exactly sharp so I'm looking to replace it. Lots of choices in terms of blade with and teeth per inch. Is there a general chart for something like this that helps select a blade depending on what you're doing? (i.e. resawing vs cutting curves)
Thanks!
Taunton (fine woodworking) has a book on bandsaws written by Roland Johnson.  it contains blade recommendations and a whole lot more useful information.   I just follow the recommendations in the book.   unlike a tables aw where there are only a couple of blade configurations you need, bandsaw blades come in way too many configurations for me to commit to memory.
A 3/8" 4TPI will be the most versatile blade for that saw if that's the only saw you have.  It can do bigger curves, rips and resaw.  It's like the jack plane of bandsaw blades.  For tighter curves you'll want a skinnier blade.  If you want a smoother cut you'll need higher TPI.  I keep low TPI blades on both my saws since no bandsawn surface is glue or finish ready...I don't care how many teeth a blade has.  You'll have to do work to the surface after the cut regardless...so you may as well cut fast.
Thanks guys! I did finally get a chance to check out some guides as far as the teeth per inch (new baby in the house). I knew that the smaller radius requires a smaller blade width, but wasn't exactly sure about the teeth per inch. I was thinking of getting a 4 and a 10-14 to have on hand to start with. Any opinions on the Timberwolf blades?
How much tolerance is there in blade length? Does it have to be exactly 98 inches or will 98.5 inches work?
  • Who's Online   2 Members, 0 Anonymous, 43 Guests (See full list)
    26,008
    Bob44
    Bob44
