Hey guys,
I'm quite desperate for help is resolving this issue. I have an old Craftsman (1977 I believe) contractor table saw that I would like to get working better. The problem is, the blade gets out of alignment when I raise and lower it.. the rear of the blade moves by about 1/64" which to me is way too much. Even with the motor and no weight on the arbor it is moving. Note, this does NOT happen at the front of the blade, just the rear.
Note, on this particular saw, the trunnions are mounted directly to the underside of the table so the "rods being twisted" problem does not apply. Could the lift screw be messed up? I am out of ideas..
Thanks.
-Matt
I don't know that saw, but I used to have a Jet contractor saw with the turnions mounted to the table. Most of those contractor saws are pretty similar in their basic design.
When aligning the blade, the trunion bracket mounting bolts half to be loosened in order to adjust them. When tightening them down again, you half to make sure the brackets fit tightly to the trunions. If not, there will be play in there, which could cause the blade movement you are seeing.
It's real easy to leave a little slop in there when your tightening the bolts. That's one of my biggest complaints with contractor saws. You need about 6 hands to align the blade.
Hope this helps.
Hey,
Thanks for the advice. The brackets are tight to the trunions. I also tried shimming the trunions which didn't seem to make a difference.
I'm wondering if my arbor got slightly bent or something? There is negligible run off so I know that isn't the problem. Sigh.. at this point I'm thinking the best I can do is align it at something like 2 inches in height and essentially try to split the different in error..
Thanks Tom. I have seen those before but I don't think it will fix my problem. As of now, I noticed the bearings could use replacing (not quite as smooth as they could be) so I have just disassembled the saw entirely and am going to replace the bearings and give it a thorough cleaning. I did clean out some packed in sawdust from the lift gear so maybe that was the problem..
-Matt
  • Who's Online   1 Member, 0 Anonymous, 56 Guests (See full list)
    26,008
    Bob44
    Bob44
