Router Bit For Art Canvas Stretchers
We're looking at getting a bunch of canvas prints to decorate a room in the house. The end result will be 3 large pictures each broken up into 4-5 piece mosaics/collages. If I buy them pre-mounted on stretchers, it triples in price. I'm curious if anyone has any experience making their own stretchers? It's a keyed miter joint with a slot/mortise for tapping a wedge into the slot to open the joint slightly after mounting. I found a website that sells this cutter for $300. At that price, I might as well just pay and have them done. I was hoping to locate the cutter elsewhere or find some alternative solution to achieve the same results. I can't identify the router bit though. The orange paint looks like CMT's industrial line, but that's all I got. I've browsed the CMT website and can't find an exact match.
I might go the cheap route and just make some rectangular frames. I'm not hanging the Mona Lisa or anything special. It doesn't have to last 100 years. But before I go cheap, I thought I would check and see if anyone here has been down this rabbit hole?
-E
Elroy, my Dad is an artist, and I helped him assemble a large canvas frame just before Christmas. That one appears to have a mitered bridle joint at the corners, and of course the wedge slots for tightening it. I think a 45* tenoning jig would make this joint easily.
If you are diligent in stapling the canvas to the frame, it should require very little extra stretching. Also, note that the stock is not square. It has a molded profile to create a relief under the canvas. This prevents any of the frame surface from distorting the canvas.
Not sure the dimensions of the cutter from your photo, but you can get a Whiteside spline cutter for about $20. On Amazon or from Woodcraft.
8 hours ago, Tom Cancelleri said:
I've stretched canvas before. I did half laps and it's been great for the last 7 years without issue.
Did you use something to expand the joints after assembly or just carefully stretch and staple the canvas around the frame?
-E
-E
Careful stretch and staple. I can take pics of it if you want.
Sure, if you don't mind. That would be great.
-E
3 hours ago, wtnhighlander said:
You iwn a set of canvas stretching "pliers"? They get things tight enough that the corner wedges aren't really necessary. At least for a few years. Like wood, canvas can move with changes to the environment.
I've ordered a pair from Amazon, they should be here when the canvas prints arrive. I'll mill and half-lap some aspen that I have lying around and give it a go. $13 for pliers, scrap wood, and a few staples is much better than $250. I can spend that $250 on some lumber!
-E
I ordered this canvas in February 2011. I made the stretchers from pine I bought at HD. I was living in my condo at the time and didn't have my shop, just my scroll saw in my closet that I set up and used to cut the half laps. I smoothed them with a small plane. Glued it up. Stretched the canvas, worked great.
Sent from my Nexus 6P using Tapatalk
  • 26,009 Total Members
  • Joseph b Newest Member ·
