suggested stains for uneven wood?
Hi - I have 4 chairs I have stripped. In process of sanding.  one chair in particular has differences in wood coloring.  I have not used gel stains before. How effectively would a gel stain cover this? I have concern that it may be difficult to use (pool) with all of the corners (shown in photo of chair before stripped).
chair.thumb.jpg.79d9a197b5b7faf86d24f54ed76de348.jpgIMAG0544.thumb.jpg.797ba2640ac2188e8f916e11ad452b6f.jpg
What you need to do if you choose not to use a tinted topcoat, which is probably the better way to go. You will first need to dye the wood to get an even tone. Then apply your stain over the dye. This will help to even out the 2 different wood tones.
You could even make a shader by adding a little stain to your topcoat to spray on after the dye and stain step, which will help dial in the color. For a shader to be successful, you need to use products from the same manufacture which can be intermixed with their topcoats.
-Ace-
All the gel stains won't stain the same. There's no ultimate answer to your question. When I fear different look between parts, I walk step by step. First, I apply a light layer of shellac (natural white wax-free shellac). It enhances the grain, but it also prevent the stain to go deeply into the wood, so each layer of stain should colour the same whatever the wood below. If I notice a difference (generally a light zone), I can mask the "good" parts, and apply another layer of stain to find the right match. Please note you can change your stain between coats to get it right. If the part seems to yellow, you can choose a brownish or redish stain instead the regular one. The more interesting in this method : it allows mistakes. If something does not goes as expected, you can sand the part to the shellac coat and start over.
Jean's method sounds a lot like "glazing":  put a finish on first, then a pigment.  you can do all manner of effects this way, alternating finish and glaze, and if you don't like something strip/sand the last coat off.  This method never actually colors the wood itself.
That's true @Pondhockey. It's the safe way when you need to practice to find the right colour. You just want to apply a good protection at last step. When you stain the wood itself, you need to be pretty confident, because there's no return.
No worries, one would work out the color using wood from the inside of the chair just under the seat with dye and stain. You have 4 chairs and that affords a ton of area for testing.
-Ace-
