Lewis Allison Posted May 31, 2018 Report Posted May 31, 2018 Hi guys!, I have a shop Fox w1825 bandsaw. And I just bought a 1” Laguna resaw king blade for it. But I can’t seem to keep it from wandering towards the fence, and cut in a straight line. I have done every adjustment I know of to take away the drift, but it seem to make any difference. Any help would be appreciated. Thanks, Lewis Quote
Chestnut Posted May 31, 2018 Report Posted May 31, 2018 47 minutes ago, Lewis Allison said: Hi guys!, I have a shop Fox w1825 bandsaw. And I just bought a 1” Laguna resaw king blade for it. But I can’t seem to keep it from wandering towards the fence, and cut in a straight line. I have done every adjustment I know of to take away the drift, but it seem to make any difference. Any help would be appreciated. Thanks, Lewis Does it jump towards the fence quickly or does it take it's sweet time drifting over.? I had a RK blade that as soon as it touched wood it wanted to take a right turn, or was it a left turn .... any way i exchanged it for a new one and it cuts laser strait. Also if you get a RK blade that leaves a rough cut like you went after the wood with a dull beaver, it might be the brazing on a few teeth. I had a blade that developed some burs in the brazing. I took a diamond plate to it and removed them and it cuts nearly as smooth as my table saw now. Quote
rc.valencia.3 Posted May 31, 2018 Report Posted May 31, 2018 I adjusted my bandsaw per this video, if it doesn’t work replace the new bladeSent from my iPhone using Tapatalk Quote
Lewis Allison Posted May 31, 2018 Author Report Posted May 31, 2018 3 hours ago, Chestnut said: Does it jump towards the fence quickly or does it take it's sweet time drifting over.? I had a RK blade that as soon as it touched wood it wanted to take a right turn, or was it a left turn .... any way i exchanged it for a new one and it cuts laser strait. Also if you get a RK blade that leaves a rough cut like you went after the wood with a dull beaver, it might be the brazing on a few teeth. I had a blade that developed some burs in the brazing. I took a diamond plate to it and removed them and it cuts nearly as smooth as my table saw now. It takes about 6” to drift 1/8”. No, I’d say it leaves a pretty smooth cut...I just can’t get it to cut straight. Quote
Lewis Allison Posted May 31, 2018 Author Report Posted May 31, 2018 3 hours ago, rc.valencia.3 said: I adjusted my bandsaw per this video, if it doesn’t work replace the new blade Sent from my iPhone using Tapatalk This is how I initially put the blade and Adjusted everything. Do I just have a defective blade? Quote
rc.valencia.3 Posted May 31, 2018 Report Posted May 31, 2018 This is how I initially put the blade and Adjusted everything. Do I just have a defective blade?Seems like you do. Call customers service first, before exchanging it.Sent from my iPhone using Tapatalk Quote
