So far the company I purchase the jp combo off of has been extremely accommodating and for that reason I care not to mention their name. I purchased the tool about a year ago and quickly brought to their attention that the tables where not flat. With a little effort on my part within a couple of days they agreed to send me a new machine and promised to thoroughly check it before it arrived at my shop. Now I have two machines that I find far from acceptable when it comes to the tables being flat never mind coplanarity table to table or table to cutter head. Please see my attached picture and confirm or dismiss my concerns. Are there any techniques that I can use while jointing to produce a high quality product with one of these machines? I expect to be able to straighten/flatten a 10' board within a 32nd. Is all hope loss?
Are the tables cast iron or stamped steel?  Have you actually used to joint a board?  What were the results?  The lengths of the table could be a bit of an issue with 10' boards if no infeed or outfeed support.
Cast iron.  I have jointed boards with fair results just shy of expectations.  My last jointer was a old 8" jet that I could get better results with.  I spent an extensive amount of time tuning that machine.  I do not wish to repeat that same experience with these machines.
  I believe with proper technique jointing a 10' board should be no problem on a jointer with an overall length of 70"
Since the tables are cast iron my only suggestion would be to ask the manufacturer to pay to have the tables ground flat and true.  Obviously you have had 2 machines with the same issue, which may be within there specs, so a third machine will be no different.
  • Who's Online   1 Member, 0 Anonymous, 37 Guests (See full list)
    26,008
    Bob44
    Bob44
