TimK5000 Posted May 16, 2025 Report Posted May 16, 2025 Greetings, I am making some 1 1/4" thick edge grain cutting boards from Maple. These boards are shaped like States and are cut with a band saw and routed using a flush trim bit and a pattern. Currently I use a 1/4" spiral flush trim bit because of the detail required. This has been a real challenge. Since the grain direction is always changing, including going from edge grain to crossing end grain the bit sometimes grabs and wants to break out chunks of the board. I am sure there is a proper process for doing this. I would like any suggestion anyone has for completing this process including the correct tools, speeds and procedures. Thanks 1 Quote
Popular Post pkinneb Posted May 16, 2025 Popular Post Report Posted May 16, 2025 What I have found is to make sure you are not trying to take off to much with the router bit if you can keep it to under a 1/32nd it will be much easier to control. 3 Quote
TimK5000 Posted May 16, 2025 Author Report Posted May 16, 2025 I will certainly try getting as close as I can with the bandsaw first. Thank you 1 Quote
Popular Post gee-dub Posted May 16, 2025 Popular Post Report Posted May 16, 2025 I am a fan of top/bottom bearing bits but for vertical edge grain that kind of goes out the window. For variable edge grain template routing I use a stepped approach. A router table makes this really easy. I understand that this is what works for me and others will have other methods that work for them. You will have to choose a bottom bearing bit of about 1/4" to 3/8" or cutting height. You want to cut a profile about 1/4" in height. Then repeat the pass cutting an additional 1/4". This may cause you to change bits so make all your first cuts at ounce, then make your second cuts, then your third cuts, etc until the height is complete. 3 Quote
fcschoenthal Posted May 16, 2025 Report Posted May 16, 2025 Compression or spiral bit will also help. They shear instead of attack head on like the straight bits. 2 Quote
