gee-dub Posted November 5, 2025 Report Posted November 5, 2025 My brother had the pessimistic saying of "nothings ever easy". I do not subscribe to this but, here I am . . . While milling material for my current project my ever-faithful Grizzly cyclone failed to start. I noticed this when the spoil from my jointer was not magically vanishing like usual. I eventually noticed that the overload indicator on my cyclone's mag switch was on. Hmmm . . . I had just checked the barrel . . . maybe the blower housing was jammed??? Out to the DC bump-out. I am always glad that I installed some lighting out here. I pulled the exhaust hose connection since that allowed the shortest distance to the impeller. The impeller and motor seem to move freely enough. On to the electrical. I was wise enough to install a formal disconnect panel for the cyclone so I can work on it safely. There is also a breaker in the main shop panel that feeds the disconnect. With everything de-energized I do a physical inspection. Everything is tight and shows no sign of distress. I re-energize the panel and show low voltage at the lugs(???). Turns out my Fluke meter had not had the batteries changes since 2022. The Simpson meters I am used to do not use the batteries for AC readouts but . . . the Fluke's do. Found a 9 volt and got good test readings on known working outlets. Voltage at the disconnect are also now good. Expectation is that a fouled cent-switch contact or blown start cap is the culprit. Either way it is a time-suck. I will keep you apprised. 1 5 Quote
gee-dub Posted November 5, 2025 Author Report Posted November 5, 2025 Confirmed everything with the energy supply to the disconnect, through the fuses and on to the mag switch. Time to look under the hood. Pull the bell cover. Pull the TEFC fan. Pull the Cent-switch dust cover. Pull the cent-switch. Huh? Think there could be a problem here? I believe I have a spare up in the attic. Will check back after I look. 5 Quote
Popular Post gee-dub Posted November 6, 2025 Author Popular Post Report Posted November 6, 2025 Nope, no spare. Part on order, but it will be about five days. I guess I will have to get creative about what things I can do between now and then that don’t involve a lot of milling. In the machine’s defense it has been flawless for many years. These machines are made to be turned on and run for many hours. I tend to turn mine on and off many times throughout the day, which is very hard on them. 3 Quote
Coop Posted November 6, 2025 Report Posted November 6, 2025 Cent switch, as in centrifugal? How does that work? Quote
gee-dub Posted November 6, 2025 Author Report Posted November 6, 2025 On 11/5/2025 at 4:19 PM, Coop said: Cent switch, as in centrifugal? How does that work? The video is a little slow but if you fight your way through it there is some good info. Tried to insert a link that starts at the cent-switch part. 2 Quote
Beechwood Chip Posted November 6, 2025 Report Posted November 6, 2025 On 11/5/2025 at 7:19 PM, Coop said: Cent switch, as in centrifugal? How does that work? So, the switch is closed when the motor is not spinning, so the capacitor is engaged. When the motor spins up, the centrifugal switch closes so the capacitor can recharge for next time. Do I have that right? Quote
Popular Post gee-dub Posted November 6, 2025 Author Popular Post Report Posted November 6, 2025 Yep. The cent-switch has the starter capacitor in the circuit when the motor is not spinning. When you hit the start button the start-cap gives the motor a kick. When the motor reaches a certain speed the centrifugal switch, via weights on the assembly, fly open and removes the start cap from the circuit. The run cap then carries on in operating the motor. It is not as complex as it sounds when you list it out . https://www.electrical4u.com/centrifugal-switch/Here's a link to a description. 5 Quote
Popular Post gee-dub Posted November 13, 2025 Author Popular Post Report Posted November 13, 2025 OK, $16 in shipping and 8 days later . . . Breakers off . . . Disconnect off . . . Remove destroyed spring switch . . . Discover two missing screws (probably put them in the pocket of whatever I was wearing during teardown and lost them. Amazingly they are 10-24 so easily replaced. I marked the cent switch position with a felt tip marker so easy to reposition. It works! BUT, there is a rubbing noise. Something I would have never noticed if I wasn't out here fooling with the thing. I will continue diagnostics. Hopefully it is something I can milk along as disassembling this beast or replacing it are not things I want to consider at this point in my life. Stay tuned . . . 6 Quote
Popular Post gee-dub Posted November 14, 2025 Author Popular Post Report Posted November 14, 2025 I have a clock / pen oiler that allowed me to get some super refined oil down into the motor works. The noise abated and operation seems normal. I will run it and check frequently. It will survive or fail but there is not obvious bearing (or other) noise at this time. We'll see what happens. 6 Quote
