I love my card scrapers and I use them all the time but I've noticed a couple annoyances I'm just wondering if everyone has these same problems or if I need to work on my technique.
First of all, I find that I only get about 2 minutes of scraping per edge before I need to re-sharpen and re-burnish the scraper. It often feels like I'm doing more sharpening than scraping. I also find that my scrapers get very hot, to the point that I'll burn my thumb if I don't wear leather gloves. Is this normal or am I doing something wrong.
I've watched the sharpening videos, and I get pretty good wispy shavings so I don't think that is the problem. Maybe I'm pushing too firmly on the scrapers?
Andreas, If you are experiencing rapid loss of your burr, I would start with thinking the burr is too aggressive. Try to lighten up on the burnishing part. Also, a light hand is all that is needed if you find the hook. The William Ng video on The Wood Whisper site does a real good job of covering how little of a burr is needed and how light of a touch to use.
For the hot hands part, that is normal, the thin gloves are IMO the best way to go. Any kind of holder will remove a lot of the control that you get from flexing the card by hand.
A pretty good trick for the heat is to put a magnetic business card on the back and push against that.
Sorry no suggestions on the durablity of the edge it sounds like your burr might be more wire thin than desired if it cuts and then maybe breaks off.
Thanks guys, that helped. I tried again using a lighter touch with my burnishing rod and the burr seems to last longer now. I was probably burnishing too aggressively.
Good idea with the magnetic business card. I'll have to stop throwing those things in the trash.
One other suggestion. When I set up my scraper I hone the edge and sides on my stones just as I do with my chisels and irons through my highest grit, I never used to spend as much time on this and once I changed my regimen I noticed not only that I was left with a slightly better finish but a longer timeframe between having to re sharpen. Just a thought.
Nate
Another tip: when it gets dull, you don't always need to resharpen. Often it is enough to use your burnisher to re-consolidate the edge, and then re-form the hook. Takes less than 30 seconds.
  • Who's Online   2 Members, 0 Anonymous, 62 Guests (See full list)
