Hand planes: do you leave the blade in position or retract it when finished?
As someone new to hand planes (I just refurbished my first plane: a Stanley 1930's low angle block plane), I have been wondering ... is it generally considered proper usage to put a plane's blade into finely-tuned position and then leave it set that way all the time (minus sharpening or re-adjusting it) or does one retract the blade each time when finished using it for the day?
I always leave mine in the tuned position (blade not retracted). That way it's ready to go as soon as I pick it up. Just ensure you store it in a way that prevents blade contact with anything metal. I store mine in a drawer sole-down.
Joe
Mine are under the bench on a shelf; much like Joe, I leave them ready to go. I have a strip of cork that the heels sit on to keep the blade from digging into the shelf and so the bottom gets air flow.
Same thoughts here. If you have a decent place to store them where they won't get dinged up, leave the blades out and ready to rumble.
-- Russ
Great. Noted. I work on the job site more than in a shop, so would need to take hand planes with me from time to time. Thus, I will need to protect the blades in some manner, whether that be retracting them or putting the planes in their own bags or containers, or whatever. But I was just curious what "proper" protocol was if one weren't running around town with tools in tow... Thanks for the replies.
I always retract the blades. Sharpening is one of those chores that I honestly don't like doing. I would rather take the extra 15-20 seconds to set the plane up when I need it and then retract the blade when I am done. A nice side effect of this is that I never chip my blades.
I store my planes on their side with the blade ready to go. No problems.
  • 4 weeks later...
I have always store them on their side - I was told many years ago " a 22inch plane placed with heal or toe raised would if left over time would 'sag' " - while I don't believe this would sag enough to put the sole out of true, I have never run the risk.
I leave the blade extended and ready to go. The shelf I store them on has a foam pad so the blade is protected.
Ha! I was just thinking about how I'd never read that before! It sounds rediculous to me. I have read that straight edges should be hung from one end or laid down fully supported (on a flat surface!).
I leave mine ready to go, sole down. Only thing to be mindful of is to pick them up when you use them and place them down, don't slide them around.
If I retracted my plane irons after each use, I'd spend more time fiddling with the irons than I would actually using the planes. I don't do anything special, I just lay them sole down in my plane cabinet. I'm not too worried about wooden cabinet shelves doing any damage to my A2 irons. I used to find that I'd spend 20 minutes flattening a board, banging my jack or jointer down the board, and then once I was putting it away I would suddenly treat it like a delicate flower. Funny in retrospect.
I'll add to the chorus. I never retract my blades for all the reasons cited. I don't have a fancy cabinet or dedicated shelves to store mine. I just use an old cart with a towel draped over the top - works fine.
  • 26,012 Total Members
  • JAR Newest Member ·
