Jwest Posted December 28, 2011 Report Posted December 28, 2011 Hello All, I was wondering if anyone had some tips on keeping your table saw blade clean. I've noticed some resin build up and so forth on some of the teeth. I got to wondering if it was important to clean the blade every so often, and if so what is the recommended technique? Thanks for the input. Jack Quote
Dynablue Posted December 28, 2011 Report Posted December 28, 2011 The simplest way to maintain your blades is using a blade and bit cleaner to dissolve the resin buildup, scrub and then wipe the blade dry. I spray the cleaner on the blade, let it sit about five minutes and then lightly rub the resin off with a brass brush. In theory the direction of the rubbing shouldn't be an issue with soft brass but I always rub from the back of the tooth towards the cutting face. The most important aspects of the blade to clean are the sides rather than the top and face of the tooth but I clean up everything. I used to soak my blades in a simple green wash but some blades, particularly the Freuds, have antivibration cuts in the blade body and those cuts are factory filled with a resin of their own which the simple green will erode as well. So now I spray my Freud blades but I still soak my WWIIs. When the blades are clean you should inspect each tooth for wear or chipping and send it in for professional rework if you notice such defects. If no defects then dry the blade off and enjoy fresh, clean cuts. 1 Quote
Beechwood Chip Posted December 28, 2011 Report Posted December 28, 2011 Marc has a video on this. Skip to about 4:00 . Quote
knotscott Posted December 30, 2011 Report Posted December 30, 2011 It's very important to keep your blades clean. A gummed up blade cuts like a dull blade, plus seals it's own fate by overheating and prematurely dulling the carbide. There are many effective ways of cleaning...doing one of them is the key. I've use store bought specialty blade cleaning solutions, but have had similar results from household degreaser sprays like 409, LA's Totally Awesome, Fantastic, Grease Lightning, etc. Spray, brush, rinse, dry....done in 3-4 minutes from start to finish. If your blades are really bad and need a soak, Freud suggests kerosene b/c it's pH neutral. Oven cleaners and soaking in Simple Green are not recommended...both work but can cause other issues with carbide and binders. Quote
