Pbmaster11 Posted December 29, 2011 Report Posted December 29, 2011 As the title says, I have a Jet planer and the wood gets stuck in there and doesn't feed properly. Any thoughts? I have not looked into the problem... it has been getting worse and worse.. now I have to push and pull to keep in moving... not very safe. Quote
Trip Posted December 29, 2011 Report Posted December 29, 2011 I am assuming this is in reference to a standard 4-post planer. if so, then probably feed roller pressure or alignment. The manual has a setup/alignment procedure. Check the sections on feed. Quote
rmac Posted December 29, 2011 Report Posted December 29, 2011 Start by cleaning the feed rollers. (Unplug the planer first and be careful not to cut yourself on the knives.) Then clean and wax the bottom plate that the wood slides on. I bet one or the other of those actions will fix it. -- Russ Quote
Trip Posted December 29, 2011 Report Posted December 29, 2011 ==> Start by cleaning the feed rollers/plate good point. BTW, my 4-post planer manual has a pretty decent troubleshooting section -- check there as well... Quote
PaulMarcel Posted December 29, 2011 Report Posted December 29, 2011 When I had that on my 4-post planer, waxing the bed 'fixed' it. Quote
