best value for small shop dust collector
i just purchased a grizzly 6" jointer and now in the market for a dust collector. i have a 2 car garage, but only half is my workshop. i want a big enough dust colllector for the future but i do not need one that is overkill. i am looking athe shop fox w1685 1 1/2 hp 1280 cfm and the grizzly g1028z2 1 1/2 hp 1300cfm. amazon has shop fox for 250 plus free shipping and grizzly is 300 plus shipping. anyone have these dust collectors and have good reviews on them???
Im sure both of those work just fine. Keep in mind the cfm rating is without the "y" adapter your not going to get even close to that much with 4" hoses. The little collectors are great for single machine hookup but do leave you in sort of a dust cloud.
Don
The shop fox unit looks like a 30micron bag, the grizz has a 2.5micron. I suggest factoring in the filtration as well as HP and CFM.
There was a review in FWW a few year back on DCs in this size. Take a look at the review at
http://www.portercable.com/uploads/PCD/Documents/News/182DustCollectors.pdf
The shop fox and grizz units are reviewed, as well as delta, another grizz, Penn state, and a few others.
hpw about buying the extra 2.5 micron bag with the shop fox. i would go with grizzly but the shipping hurts! aamazon is free with shop fox and extra bag? thanks for the help
FWIW - I have the Delta 50-760 (came out tops in that review) and I think it does a very good job. It came with a 1u bag. The Grizzly 1029 (the 2HP unit, not the 1.5) was also recommended, although I would replace the bag with something better.
John reminded me about filtration. If you get the HF DC you'll want to get a Wynn filter for it.
Couldn't agree with this more. You dont want to get anything with a 30 micron bag. You might as well take all your shavings and throw them in the air a bunch, casue that is all the 30 micron bag is going to do. The better option would be the 2.5 micron.... .5 micron would be even better.
so buying the shop fox with a 30 micron then replacing it with there 2.5 micron bag or 5 micron bag would be goodan ok choice?
if you're going to replace the bag, I would recommend that you not go with a 5u. A 2.5 is ok, but look for a 1.0u or 0.5u
Edited by John Fitz
Reminds me, at my doctor's office there's advice for writing perscriptions. It says that you should always use a leading zero before a decimal point, because, for example... .5 can look like 5, but 0.5 is more obvious.
Good advice!
I find it somewhat ironic that good advice on making something easier to read came from....a doctor's office :)
Same thing with my doctor's office. Maybe we go to the same place!
Another vote for the HF, and the Wynn filter upgrade. By far the best bang for the buck. Also suggest you google the "Thien baffle" and build one, either in the ring or outboard. This works on any of the DCs that don't have a cyclone. That will keep a lot more dust out of the filter. Are you planning to hard plumb it, or just use a piece of flex duct?
If you hard plumb, 4" PVC S&D pipe works great. Just don't use any 90 degree elbows or T joints. Instead, use 45s with a short piece of straight pipe and Wyes. Lots of folks don't glue the pipe, they just tape it so they can replumb easily. Use blast gates so you only have one machine at a time connected to the DC.
If you use flex, don't go over 10'. Lots of folks like the Rockler dust-right hose and accessories for this, but the basic flex pipe works fine if it's short. Lots of sources for the connector that will slide over the inlet ports and let you clamp the flex to it so it's easy to move.
You don't say what kind of TS you have, but if it's a contractor saw, plug up the holes front and back and get a pan with a dust port that goes in the bottom of the sheet metal. Might have to remove the shields when you tilt your blade.
You can also make or buy a downdraft table top that will make your sanding more pleasant.
But, most of all, get the 0.5 micron filter. The canister filter is a better deal. It costs more, but it is more efficient = you get more suction and CFM from your DC than you do with the bags.
thanks again for more info. i have a jet proshop hybrid. it has a 4 dust hood. do any of you have the harbor frieght dc? it does seem like a cheap priced unit? if it works well it maybe something to look into i guess. how is quality for use down the road in the future? i am fairly new to wood working but do have some projects under my belt.
The HF DC seems to have enough oomph to satisfy most users, but I don't think it's at the same level as some of the better 1.5 and 2hp units from Jet, Delta, Grizzly, PSI, etc. The last I knew that motor can't convert to 220v, the switches are prone to failure, and the impellers are smaller, which ultimately moves less air, so it does have a bit less potential if you were to expand or upgrade down the road.
Here's a pic of the impellers from a 1.5hp Griz DC vs the 2hp HF:
  • 26,009 Total Members
  • Joseph b Newest Member ·
