hello, i have a 12 year old Rigid 12" compound saw with a Freud blade on it. it has been great until now. i have just started to learn how to build furniture so exact cuts have never been an issue, just stripped the saw down cleaned and lubed, 90 degree cuts are just about perfect, but when i turn it to a 45 degree cut the cut is off any idea on how to fix this or can it be the blade ? thanks
Are you making a bevel cut or rotating the table 45°? Ridgid, Craftsman and Ryobi miter saws are all made by OWT/Ryobi. All of these miter saws had, maybe still do, a problem with the table flexing while making a bevel cut if the blade wasn't lowered just so into the work piece.
went through the adjustments in the manual, even purchased 2 new squares at 90 degrees blade is square to fence an table also shows square to fence at 45 degrees,not making a bevel cut just turning to make a 45 degree cut. i dont know the best way to describe it is the miter comes out at a perfect 90 degrees but when i put the two cut parts together there is about a 1/32 in gap at the bottom of the face of the joints.it is like the bevel adjustment changes when i turn the table.but when i check it it shows square. thanks
Check for blade issues, like flex. Install a good blade, if you have a good blade for you TS then swap it out.
Don
+1 I just finally spent the money and put a good full kerf blade on my miter saw. ANother thing to think about it your technique. When you are making th ecut, mak sure that you are pulling the saw straight down. Try to make sure that you arent putting any lateral pressure on the saw. I know that my saw has a TON of flex in it. It doesnt take much to make things go out of square. But I have a cheapo miter saw and that is also why I dont use it for finish cuts. It is used most for roughing out big boards, and when I dont care about PERFFECT squareness. If you really want to get the best results, I would recommend investing in a quality miter gauge for your TS.
Or some specialized sleds if you're only doing, say, 90 degree and 45 degree cuts. If you routinely do a bunch of crazy angles, then a good miter gauge would definitely make more sense.
-- Russ
-- Russ
That is another option as well. A good one at that.
  • Who's Online   2 Members, 0 Anonymous, 50 Guests (See full list)
