jeremymeeks Posted April 28, 2012 Report Posted April 28, 2012 Hi all, Last night I started working on a project when I heard a very disturbing sound from my 10" Craftsman contractor's saw. As I was feeding a piece through the blade, the saw started to shake slightly and it sounded like something was rubbing or grinding. I immediately turned off the saw, unplugged it, and removed the blade. I checked what I could, tightened any loose parts, and started the saw again with no avail. Any suggestions? Jeremy Glen Burnie, MD Quote
rmac Posted April 28, 2012 Report Posted April 28, 2012 Try this:Unplug the saw.Make sure the saw is unplugged.Have somebody else check to make sure the saw is unplugged.While rotating the blade slowly by hand, listen for any scratchy sounds and feel for any roughness as you turn the blade.If you don't hear or feel anything, well you tried.If you do hear or feel something that doesn't seem quite right, try to isolate the problem by doing stuff like this:Remove the blade and see if the problem goes away.Remove the belt. Then try turning the motor and the blade independently to see if the problem is with the motor or something else.Remove various guards and covers and shrouds one at a time and see if the problem goes away.Etc., etc. I bet with a little systematic fiddling around, you will be able to isolate the problem. Then you can worry about how to fix it. -- Russ Quote
knotscott Posted April 28, 2012 Report Posted April 28, 2012 Could be several things. Bad belt, belt tension, belt alignment, arbor bearings, pulleys, motor, motor bearings, motor mount, to name a few. Pulley alignment and belt tension are also easy to check. You can narrow things down by removing the belt and run the motor (with the saw unplugged as Russ suggested!) ....if it runs smoothly, the motor isn't the issue. While the belt is off, check it over good. Check that a pulley isn't loose on the shaft. Be sure the motor is bolted to the motor mount properly. Quote
