Tony Wilkins Posted May 7, 2012 Report Posted May 7, 2012 Reading The Anarchist's Tool Chest and something was pointed out that I was curious about. One of the reasons he doesn't recommend Japanese chisels is because they are metric. For those who use Japanese or other metric tools (especially chisels): does this pose a problem for you in a world of imperial wood sizes? Quote
PaulMarcel Posted May 7, 2012 Report Posted May 7, 2012 I don't think so. I rarely have something I'm paring that's the same size as a chisel. Cleaning sides of mortises isn't sized to a chisel anyway. The ends of a mortise can be better served with a mortising chisel sized to the width of the mortise, though, so the stout square sides clean the corner. But who is to say your mortise has to be in imperial sizes if that's the perceived problem. If you're using a tool to create the mortise, create it to a metric size if that's what you want. Quote
DeGauss Posted May 7, 2012 Report Posted May 7, 2012 I have a set of metric Narex chisles that I have used for years and I have never had any issue. -Gary Quote
wilburpan Posted May 7, 2012 Report Posted May 7, 2012 The only time that having a chisel that was made to a specific size matters is if you are chopping a mortise in a groove. Then it's nice to have a chisel matched to whatever tool you used to make the groove (plow plane, router bit, dado head, etc.). And even then having a chisel that is very slightly narrower than the groove might make it easier to chop that mortise. You could always pare to final fit. But that's really not a metric/imperial issue. That's just matching tool sizes. If you had a 6.1mm router bit and a 6.1mm wide chisel, they would work perfectly well with each other. And if you really had to, you could grind down the width of the chisel to suit your needs. Quote
