Pbmaster11 Posted June 5, 2012 Report Posted June 5, 2012 I just purchased a delta jointer off of CL. When I run boards across the blades it takes material off the front part of the board and slowly decreases till about half way on the board. No matter how many passes, no matter what material. Is it the blade setup? not co-planar? Quote
mikem Posted June 5, 2012 Report Posted June 5, 2012 Could be either or both. Check the outfeed table, make sure it is not drooping, and check to make sure the knives are at the same height as the outfeed table. Quote
Trip Posted June 5, 2012 Report Posted June 5, 2012 Marc has a video podcast on jointer setup. it's pretty good. it may help. Quote
wdwerker Posted June 10, 2012 Report Posted June 10, 2012 I think that is a symptom of blades to high or not keeping pressure even while you make your pass. Quote
