duckkisser Posted June 6, 2012 Report Posted June 6, 2012 i need to plan some cnc routed discs but i dont know what kind of program i would need to plan it out. need to plan some way to cut discs for a cnc router for all different size boards. how would i go about planing these out for a cnc router. i am having a tool and dye maker rout out these discs for me but he asked me to plan out the images to put into the computer to have the router do the work for him. Quote
dwacker Posted June 6, 2012 Report Posted June 6, 2012 See if sketch up will export dxf. Most cam apps will import dxf of course you will want to draw 3d and make sure depth is correct. Use actual thickness so measure stock. This way he can quickly import into his cam set the tool and produce a g code file that won't eat up his sacrificial top. Quote
duckkisser Posted June 6, 2012 Author Report Posted June 6, 2012 as for the sacrificial top we are planing only cuting part way in board. then i will put it on drum sander and sand down till i can pop lose the discs. on the plus side i can leave in board form till i need for job or till im ready to make more parts. thanks ill see about dxf files. Quote
mar10 Posted June 6, 2012 Report Posted June 6, 2012 Hi You may find this site helpful. www.vectorart3d.com Click on downloads. Check out the 3D Machinist (Free Software), Video Tutorials and free Models. Let me know if I can help out. Quote
duckkisser Posted June 6, 2012 Author Report Posted June 6, 2012 ill check it out my plan is fairly simple just a bunch of discs of different sizes with rings, and pictures that i will fill with inlays. Quote
junebug Posted June 13, 2012 Report Posted June 13, 2012 I know this post is a few days old, but if you still need it and If its something quick and easy, send me the dimensions your need and I'll bang something out on my lunch break. Quote
duckkisser Posted June 13, 2012 Author Report Posted June 13, 2012 thanks june the guy that i talked to said that he can nock this up realy easily and wont need any images since its just a barrel shape. just need demensions. but if this works i might ask you help in the future to plan for routing out some small images inside each circle. those i can fill with inlay material. Quote
