After having Matt Cianci sharpen my crosscut saw, I decided to sharpen my rip saw myself. Things seemed to go well; looking at the teeth under a magnifier they seem to be sharp. I set them according to the general advice.
So it cuts fairly smoothly, but ripping seems to go more slowly than cross cutting. I've notice this on my bandsaw too so I figure it's just a ripping vs cross-cutting thing. But I can't figure out why this would be the case.
Has anyone else noticed this before?
In my experience the rip saw cuts much faster. There are many variables in play however that might be causing your slow cut. First aim for a 60 degree cutting angle for the optimum cutting of rip teeth. If you lower the saw to 45 like a cross cut saw, the chisel rip teeth will take smaller/shallower bites and slow down the pace. Pitch of the teeth is a big deal too. I rarely use a rip saw pitched finer than 6 ppi and usually live in the 4-5 ppi range. Bigger teeth are stronger and will remove more wood but more important is the larger gullets that result from a lower pitch. Rip saw dust is different from cross cut saw dust just as cross grain plane shavings look different than with the grain shavings. The rip saw dust is bulkier since the wood is being chiseled away and thus it fills up the gullets faster causing the saw not to cut if the pitch is too high for the stock thickness. Also another reason why the steeper 60 degree attack angle is necessary as the lower angle puts more teeth in the wood preventing saw dust clearance. Finally, if your rake angle is relaxed then the saw won't cut as fast. It will be easier to start and maybe create a cleaner cut but this is the trade off for speed.
Ripping usually means a longer cut anyway so I would rather do it fast leaving a rougher surface that I can more easily true with a jointer plane than sweat at it twice as long with a finer pitched saw just to get that cleaner cut line that I will still have to plane.
Although its something I haven't really noticed or paid attention to, it makes sense to me. It's the same thing as planing across grain vs with the grain. The fibers are much stronger with the grain.
(null)
Thanks RenaissanceWW; I was hoping for a response from you. I just sharpened the teeth as they were - not changing anything.
I'll do a bit of reading and maybe have another go at it. I'm all set up to sharpen anyway.
BTW, I have 7 TPI. Might be a little fine.
