tung oil and citrus solvent
I was reading a finishing article the other day on this, though the article left a lot of infomation out. It is my understanding that the citrus solvent acts as a drying agent, so that the tung oil will dry faster (1:1 ratio). When dry, the citrus solvent (toxic) is completely removed from the finish (so the remaining finish is good-ole 100% food safe tung oil)
Does this sound right?
Also, if a person was to use 3 or 4 coats of the 1:1 ratio, would it build a film finish? Or would the tung oil/solvent saturate the wood and form no film?
That's what the low VOC formula for Sutherland Welles polymerized tung oil is. I have only used the normal formula, but yea it does build a film. Still a very close to the wood look and feel. Tim Rousseau uses it on the newest FWW video series. Looks great! So far my favorite finish. Super easy to apply and repairable.
(null)
I used the stuff from the real milk paint company which I like alot. I used it undiluted on a kitchen table made from walnut and one year after finishing it it still looks great. It will need a re-coat soon but it still doesnt let spills soak in. I found it to be fairly quick drying.
I always go 24hrs between coats anyway, because of time, but it dries much faster than pure tung oil.
i have never worked with tung oil what can i expect from working with it? how shiny does it end up being?
i have been having good luck with this process
i put wax on my lathe turning and sand all the way up to 600 and take away most of the wax. i then buff the surface to remove any excess wax and remove any left over sawdust, grime. after that i use a combination of shellac, BLO, and denatured alch. it leaves a realy nice shiny surface that does not pick up too many finger prints once i put multi layers of shellac on the turning. i know they say dont put shellac on top of wax but i end up remove almost all traces of wax through the sanding process that im fairly confident that 99 percent of wax is gone. only time will tell if my process will work out or not but initial trial is positive.
Actually, for the tung oil, it isn't recommended to sand above 220. It seals the wood too much to let the oil properly penetrate. The beauty of an oil finish is that is DOES penetrate the surface and allow light to refract differently than a top of the wood finish. Sutherland Welles used to have a really nice gallery of customer projects as testimonials. I just checked the site, and it has changed. There isn't a good gallery anymore. I'll need to call and find out why. Here's a photo of the cradle I built that was four coats of the tung oil. The first is heavily flooded, the second less so and the subsequent coats applied like you would a liquid wax. I only sanded to 180 and did not want a higher gloss. The finish has held up very well, and again, I like that it is repairable should it ever need to be touched up. I'd rather promote the use of coasters and trivets for any tables and still be able to repair without ever needing to strip an existing finish.
dont know how well it would work for turning then since i normaly sand to above 600 to remove any and all scratches. need to pick up a can of it and see what i can make of it.
