what finish can I put over danish oil?
Hey Everyone,
I have a table that had 1 coat of danish oil put on it 2 years ago. I would like to put a finish with better protection on it now.
Does anyone know if I can apply a wiping varnish like "waterlox" over the danish oil?
Or is there a better finish for a dining table?
Thanks for the help!
Hey Everyone,
So long as you thoroughly clean your table removing any wax, dirt, food stuff. If you don't, the new finish may not play nice with the old. I would suggest a good washing with mineral spirits. Let it dry a week or two, quick scuff sand, then go at it. Maybe, reapply the danish oil to renew the color. Let it dry a week or two, just depends. Then go over that with a good topcoat.
-Ace-
Danish oil is simply extra thin wiping varnish with a little more oil and a churched up name. "Danish Oil" markets a lot better on a label than "thin wiping varnish with extra oil, possibly with a pigment and/or some dye". :D
That's not to say it's a bad product, I really like Watco Natural on my workbench, and the Dark Walnut on certain walnut items, like frames and lamps.
I've occasionally used it as stain under film finishes. Once it's dry, I've successfully overcoated it with oil varnish, shellac, lacquer, and water based finishes. Under water base, it needs to be absolutely dry, or barrier coated with dewaxed shellac, before applying the finish.
If you follow Ace's suggestions, just about any varnish will work well, and Waterlox is a terrific, high-quality,oil-based varnish.
Zig, let me just add here that what Ace said about getting the wax off is especially important. If you used the Watco system, they sell a wax that you put over the oil. Even that requires that the oil dry for 72 hours, so make sure you let it dry good too. Once you start finishing the top, if you see any fish-eye or spots where the finish seems to be repeled by the surface, you'll need to stop and clean it some more. Wax and silicone can be extremely hard to remove at times and will ruin your best attempts.
Thank you everyone!
It's had 2 years to dry so, I should be in good shape after a good cleaning.
