CessnaPilotBarry Posted October 1, 2012 Report Posted October 1, 2012 I'll reply by staying to the spirit of the OP's post without getting into all the other stuff that makes people respond with, "oh, no! not another SawStop thread!" Just a month ago, I had a table saw accident. I nearly cut off my pointer finger while removing an off-cut from the blade while it was still running. Ouch! Glad to hear it was repairable! One of the neat things about the SS design is that the system is still "armed" during coast down, after the switch has been turned off. There are two LED's near the switch that flash to warn you the saw is coasting and still watching... When the red LED stops flashing, the system is disarmed and you can touch the blade without firing the mechanism. The system is smart enough, that even if you accidentally switch off the "logic" switch while the motor is running, it will not actually power down until the blade has slowed to a safe speed, as in nearly stopped. The extended coast down time of a stack dado is the reason why Euro-spec saws have arbors that are too short to accept more than a single blade. I see the ability to protect the user during coast down and still accept a stack dado as another good use of the technology. Quote
Jfitz Posted October 1, 2012 Report Posted October 1, 2012 Joe - I hope your recovery goes quickly!! You make it sound like a mnor injury but then you use the worde "mangled" *shudder*. Get well!! FWIW, I own a SS PCS, and even *I* cringe and think "Not another SS thread". I decided that it's the right saw for me, and others own saws that are right for them - for whatever reason. Quote
knotscott Posted October 1, 2012 Report Posted October 1, 2012 The reviews I've read say that the Sawstop is comparable in quality to other saws in that price range. The safety feature is essentially free. The problem is that the brake action is very forceful. In order to withstand a braking event without throwing things off-kilter, the saw has to be built like a tank. So, you can get the Sawstop brake in a high end saw that's built like a tank, but not in a lower end saw. At least, that's what I've read. I haven't been in a position to compare the saws side by side. All of the Saw Stop models that I've seen are well made, but as with anything, their lineup differs from model to model. I'd have to agree that the top Saw Stop ICS model, and possibly the PCS are comparable to other top shelf cabinet saws in their respective price ranges (PM2000, Unisaw, General 650, etc). However, the contractor saw runs a minimum of $1750, and easily gets closer to $2k for the better fence and solid wings. While it's well made as contractor saws go, it gets pretty severely trounced by the heft and muscle of the $1300 to $2000 3hp cabinet saws from Grizzly, Shop Fox, Steel City, Jet, GI, etc. The safety feature on the contractor saw comes at a steeper premium.... it's still the lowest cost approach to getting that technology in saw, but I don't think it's as good of a value as some of the other models. 1 Quote
