Sun fading on pre-finished cherry plywood
As the pictures show, I had some sun fading occur on a piece of cherry plywood I had in the garage.
The plywood is unfinished. Will these differences in color sand out or should I put the piece back in the sun? Or is these some other fix?
Thanks,
Shawn
I would try setting it in the sun and see what happens, sanding probly isn't an option beacause the veneer is usually very thin, and you may sand through to the sub plys before you achieve your desired objective. This sucks I know it was probly some very spendy plywood good luck.
I agree with higtron...sanding is not the option in this case. You have to let light of some kind even it out. Just watch out for going too far...
I'd tan it...
Remember, cherry doesn't fade, it darkens in sunlight. It's the lighter spots that need to catch up.
In a worst case scenario, you could give it a rub of BLO. The oil will darken the wood and may help even it out.
Cover the dark areas and set it in the sun. Watch it closely, check every hour or so. Cherry darkens in the sunlight. Afterwards a light sanding and finish as you normally do.
  • 26,012 Total Members
  • JAR Newest Member ·
