hobby shop heat
Len, do you have to clean the unit often? I would think that any unit like that might require a lot of maintenance. I have a through the wall AC unit and built a prefilter for it so I would not clog the coil.
BRuce
Bruce, It doesn't seem to get all that dirty. The unit I have has slide out filters that are easy to clean. I have taken the front off the unit and cleaned the coil but it wasn't all that bad. I'm not paranoid, but I do try to collect dust at the source. I also have a ceiling mounted air filter which I run for about a half hour after an unusually long day in the shop. As I recall the unit cost me about $1,000. My garage is well insulated so the unit does not run constantly.
but after the drought we had in Iowa this year,
So this year, I trenched a 1" gas line approx 150' to the garage, then installed a hanging 75k btu gas heater.
Bachambers,
I have two questions for you.
1 - Did you run the gas line yourself or did you have that work done?
2 - Where in Iowa are you. I am in central Iowa and interested in a similar heating idea.
Thanks
Chet
Here in Ohio, we are allowed to do our own digging as long as we call to check for underground obstructions first. (811, if I remember right.) Running the lines can be done by yourself, but Code requires that someone from the gas company inspect the line prior to final installation. This probably is to make sure all connections were done correctly, but the common feeling is that it's so some contractor or supplier gets their slice...
Having witnessed several people lay the pipe and do the basic connections, I don't see what the big deal is. (Aside from the fact that they're taking my pipe clamp material away, that is.)
haha!
When I built my home, it was only a slight cost increase to add radiant heat to the garage [shop]. It is simply one more loop in the hydronic system. Does not warm up or cool down quickly (hours for changes), but it is a nice steady heat. I do not keep the garage as warm as the house - only around 60 degrees - but it is much nicer than outside. Besides the efficiency, it is extremely nice not having any ducts or coils to keep clean. Kinda hard to retrofit however unless you are going to be pouring a new concrete floor already (there are some other ways to get radiant heat, but there are additional drawbacks).
I'm in the process of designing my next shop. I have the same concerns, how to keep it warm and workable in the winter and reduce/eliminate fire hazards. I recently became aware of radiant IR heating pannels. They radiate infrared energy and warm the objects in the area, not the air itself. As the objects warm, they radiate heat into the air. They're very efficient, you can hook the system up to a thermostat, are quite affordable and can just hang on the walls/ceiling of an existing shop. I'm thinking they'll be the way to go for me.
I'll probably heat the shop to 72 or so when I'm working in there, but turn it down to 60 or thereabouts when I'm not in there.
http://www.heatinggr...el_heaters.html
I do have a radiant heater, but it is not really sufficient to heat my space. I suppose I could just add more, but I was looking for a more permanent solution. Thanks for the idea!
  • 3 weeks later...
post-2771-0-77414500-1354559899_thumb.jppost-2771-0-52141900-1354559909_thumb.jppost-2771-0-79145100-1354559916_thumb.jppost-2771-0-21516400-1354559925_thumb.jpOkay, I took the plunge and set up a gas furnace in my shop. Holy cow, I should have done this from the get-go. The gas heat is quick to warm the shop and a lot cheaper than my electric heater was. The unit I put in is an 80,000 BTU unit. This is probably more than I need. However, Lowe’s had them on sale and it wasn’t much of a price difference between the 4 sizes. 40,000BTU; 50,000BTU; 70,000BTU; and 80,000BTU. Plus the 80,000BTU came with a free thermostat.
It really wasn’t a difficult thing to install. I did the whole thing myself. Running the gas line was a little challenging. I ended up needing a little help fishing the gas line down through the wall to my basement. It runs from the basement, up through the wall, to above the ceiling, across to my shop, which is in the second of two 2-car garages.
Now my shop gets warm and toasty in no time. Not only that but I have another 220 volt circuit I can dedicate to something else.
My only piece of advice is; do not buy the venting kit. The venting kit is like a hundred bucks give or take. The parts I used out of it total to about 26 bucks in cost. The kit is for standard installation. I don’t know what that means but mine seemed really straight forward and it wasn’t “Standard”. I had to buy parts and I have most of the parts of the kit left over.
Here are some pics which I hope show how nicely the whole thing turned out.
BTW – Thanks to Bachambers, who helped me with some good information to get this done.
wow - nice job!
Nice Job Chet! If it's really cold outside (you may have not hit that just yet) but the 80K BTU should warm it up pretty quick?
PS....Chet...update your profile. I never knew where you were from until today. Heck....i don't blame you on going with the 80K BTU unit!! It gets cold in Iowa yes?
One thing to keep in mind is that you have to keep the standby and working temperatures not too far apart or bring the temp up slowly so you don't cause condensation. I run 58-60 in standby and 66-68 for working without any problems but my heater is smaller and it takes 30 - 45 minutes to come up to temperature.
BRuce
BRuce
That's actually a really good point I hadn't thought about. I'll either have to ratchet the temp up slowly. Or leave the shop at a standby temperature. ... Thanks for the tip.
Of course, leaving it on stand by means you HAVE to visit the shop more frequently, to justify leaving the gas on more.
(Go ahead, twist that arm....) :D
Well, it finally got really cold here in Central Iowa. We even got a bit of snow. I spent a lot of time in the shop this weekend. I am happy to say there's no buyers remorse with regard to switching to gas heat in the shop. I kept it so that a long-sleeve t-shirt was very comfortable in the shop all weekend. I'll report again when I get my energy bill, but I got to figure at 13 cents a kilowatt hour for electricity, my gas heater may have already paid for itself.
Don't mean to barge in if i am not on topic but small wood burning stove.... is there a super small unit available? for a small garage?
The problem with small woodstoves is that you need small logs to burn. You can use scraps to start your fire, but you will want something larger to provide and sustain heat. I have a fairly large unit in my home, and I wish I would have went with an even larger unit so I could burn larger logs.
Finally Chet!! Maybe now you can send some cold weather toward SC. It was 75 degrees yesterday! You wont regret buying the heater. I look at things like this as another $75 or $100 a month to comfortably do what you love - and that cost is only for about 4 months. Guys around here pay $2000, $3000, and $4000 for a hunting club membership to "do what they love" and it lasts for 4 months...that's all AND that fee is every year. Don't get me wrong....I love a cold morning @ 20' in the air as good as anyone, but the cost here has just gotten crazy.
I have a Torpedo heater that puts out 125000 BTU's and since my shop is only 11x21 it takes minutes to heat it up nice and toasty. then i shut it off and when it gets chilly again i hit the switch. My shop isnt insulated but it holds heat for a decent amount of time...
There are small wood burning stoves out there. There are a couple that have been built for the tiny home industry, but I have not located any retailers yet. I'll check back once I find some.
I checked out the link you described and am intrigued. I'm also curious as to whether you followed up on this and how it's working out for you.
