hobby shop heat
Right now I use a small electric heater to "take the edge off" of cold fall days in the shop. In the winter, I'm pretty much shut down for the coldest months (Dec, Jan, Feb, most of Mar).
I was condsidering my options, and wondered how many people keep thier hobby shops heated all winter.
Do most people heat 24 hours a day and just turn the heat down when they're done for the day? Or do people mostly turn the heat off for the time they are away from the shop?
Hi FP - I guess I'm lucky in this regard, as my shop is in my basement. Although I don't have any dedicated heat to the shop, there's enough ambient warmth so my shop rarely goes below 60. I just renovated and added some shop space (new foundation), and also replaced the heating system with a more efficient one, so I'll have to keep an eye on it to make sure it stays OK.
For detached shops - from what I've read it seems all options are open.....like you, some shut down for the coldest months; others warm the shop while working just to take the 'chill' off, and yet others keep it warm full time. Some heat with electric or propane heaters, some use wood or pellet stoves. I guess all options are on the table, and as long as fuel cost is not prohibitive for your budget, all options should be considered.
I use the tradition wood stove. I only burn when I am out there, so I am in the heat when I need it bunch.
My shop is my 2 car garage that is tucked under the house. I have a natural gas garage heater in there. I run the heater when I'm in there to keep the temp around 68-70 degrees. When the heater is off the temp in there only falls to about the mid 30's. When I go in there, I flip on the heat and the shop is warmed up in about 15-20 minutes. I installed the heater last fall (Just moved into this house spring 2011). I was surprised how low my heating bill was... :)
Prior to that, I used a kerosene heater in my detached garage while in college. That seemed to work pretty well. The only downside with that heater is the fumes are in the room with you, so you have to have some sort of fresh air intake (open door, etc). I was "lucky" because that garage was pretty drafty.
I have an electric fan heater for instant heat. I also have a portable butane heater that gives out loads of heat. You do need to have some ventilation for that though. I am also looking into a wood burning stove. A bit like the one in the Great Escape but without the tunnel underneath :)
How cool would that be!!! You truly could have a 'man cave' under there!!!
I have wood burning stove, and only heat while I'm working in the shop in about a 1/2hr it's tee shirt weather inside, cold and nasty outside.
I have a gas heater in my 2 car garage, if its nasty cold out I will leave it on low all night and crank it up a little during the day when I'm in there. Under normal conditions I only run it when I'm working in the shop. It was the best thing I think I have ever installed in my garage!!
In the past I've used a kerosene torpedo heater but now I'm considering a ductless split HVAC system a little on the pricey side but when it gets into the humid 90's I just can't take the heat anymore.
I work in my shop every morning from 8-10:30. A wood stove would be great but takes too long
to get going and leaving it burning when not there to watch it not an option for me. Forced air
heater burning diesel (half the cost of kerosene) and two layers of clothes works best for my
situation. After about an hour of aclimation walking back to the house at 75 degrees feels
like 90. My shop is not air tight so I have no issues with fumes. The forced air heater at 125btu's
takes less than 10 mins to go from 20 to 70. Shop is 24x35 with 10' walls and 16 foot cathedrel
ceilings. When I designed my shop I intentionly made a 10x10 room to use as a assembly room
that is insulated and a small electric heater maintains that room. It also serves a room that protects my
electronics from dust and my hearing.
post-5469-0-75787200-1349834489_thumb.jp
post-5469-0-17091800-1349834512_thumb.jp
My father-in-law was a woodworker through the 60s, 70s, and 80s here in SC. He had a small shop but heated with a "pot bellied heater". He could burn coal, scrap wood, or oil. He would set a fan to blow across it sometimes. His shop was always toasty warm. The "oil" was interesting. He collected used motor oil and distributed the oil into the heater through a very small copper line. The size used for ice maker lines. He had a small valve on it and it was "gravity fed". He would start a small fire in the stove with wood and then open the oil valve so the oil could just drip every few seconds into one of the openings. Cheap and effective.
Franklin Pug (Men in Black dog named "Frank" :P ) I'd surely figure out something. Over the next 30 years, while we're all working, you only get to work 20 if you cut out a third of each year. I use this to knock the edge off. Usually that's sufficient because though it's clean propane, it's not vented. They do make all types of propane and natural gas heaters though. I just hate to see anyone have to stop for 4 months.
I was thinking about this thread today as I was bringing in all my glue, caulking, paint, and other items in the shop that should not be subjected to the cold. We are in a cold snap already, and there is frost/ice in the mornings.
I will use the electric heater for now (fall), and finish up a few last projects. I was considering putting a 2nd shop in the basement of my home, for hand tool use only. This way I wont need to worry about major DC and fine dust. I could still keep active for the winter, if I can't decide on a heat source for this season. If i need to rough cut a board on the TS or CMS, I can still do that in the shop as I wont be out there for long.
My shop is 1/3 of a 3 car garage. It was specifically built to be my shop so I have a non vented propane heater and a "window" AC unit that is built into the wall. I maintain a minimum temp of 60 in the winter and maximum of 80 in the summer. The idea is to maintain a non condensing temperature to minimize the rust prevent issues with glue and finishes. My cyclone is in the shed behind the shop and the filters are in the shop so the conditioned air is recirculated. With good insulation and the recirculated air, it keeps the costs inline.
BRuce
Bruce....curiosity question....ho do you arrive at the "non condensing temperature"?
I built my shop about 15yrs ago and did all I could to make it efficient. I have a natural gas furnace in there thar I keep at 56 all the time and when I am out there I bump it up to 64 which is very comfortable with a sweatshirt on. Since the shop is kept at the 56 degrees all the time it takes no time to heat it up the rest of the way.I know the first couple yrs I heated it the increase wasn't much at all but I don't keep track anymore, prices are too depressing to figure out where it all goes! I have a 1000 sqft shop that during the winter we try to only open the overhead door when we have too, which is almost never since cars almost never come in:)
Hi Tim, there is a big calculation that can be used but the biggest part is not making a drastic change in either direction. The delta temp is what will cause the condensation. Like Nate, he moves from 56 to 64. Not a large change in either direction. But if the temp is 40 and you raise it to 65 then everything sweats and that is not good. Find a temp you like to work at and then drop the temp 10 when you leave. The next time you heat up the shop, look for signs of condensation. I have an old grinder in the unheated shed and just cover it with a towel, no condensation or rust in 5 years or so.
Also, everyone tells me that my unvented propane heater will cause everything to rust because it creates water vapor as it burns but so far no more rust in the winter than any other time.
BRuce
  • 3 weeks later...
I have a detached 26x46 garage with the shop taking over about half the garage. My preference was to wall off the shop so that I had less room to heat and cool, but the wife didnt like that idea. I started out with a salamander kerosene heater , but I hated smelling like kerosene, not to mention the headaches. Last year, I tried a 50k btu corn/wood pellet furnace that I got cheap on craigslist, which did an okay job of heating the garage. I purchased corn from an elevator in town, but after the drought we had in Iowa this year, corn prices are high and its no longer economical. It was really a blessing in disguise, because the furnace was a maintenance nightmare. I spent more time, unloading corn, filling the hopper, cleaning out the ash bin, cleaning the pot, cleaning the exhaust than I did woodworking.
So this year, I trenched a 1" gas line approx 150' to the garage, then installed a hanging 75k btu gas heater. I set the thermostat at 55 degrees, since the heater needs to be at least 50 to fire and I want to keep finishes, glue, etc from freezing. It takes approximately 10 minutes or less to bring the temp up to 68-70 degrees and I can wear short sleeves. I spent approx. $1600 between the piping, risers, trencher and heater, but looking back I should have just bit the bullet last year and saved myself the headache. Its nice to be able to set the temperature and forget about it.
Good Luck
I don't heat my shop at all. It's too small to justify the expense, even for a small space heater meant for a bedroom or corner of a main room. (Plus, the large open holes on the outer wall kind of defeat the purpose... and the landlord will not allow me to seal them off.)
The only thing I have done is store the glues and finishes in the back corner, right next to the brick wall that the other side of the kitchen. I wrap a fleece blanket around it in winter to reduce the cold temperatures, but that's it. (I haven't opened the one can of finish I've had since last winter, so I can't tell you what the effect of this approach is yet.)
Before I had a woodsove in my shop, I use to use an electric reflective dish heater, and just aim it at the area I was working in, not really trying to heat the shop just trying not to freeze my butt off. When I was doing a glue up I would throw a piece of platic sheeting over the project, and than an old electric blanket over the top of that and turn it up to medium.
I've always thought a wood burning stove would make sense in a wood shop but worried about an open flame in a dust filled area as well as the way a wood stove tends to dry out the air. Apparently some of you guys are doing it though. I am curious if any of you have problems with boards warping from the dry heat to cold cycling?
My shop is about 25' x 30'. Last year I installed a "motel" type unit. I'm cool all summer and warm all winter. Southwest Ohio. I ain't big on leaving thousands of dollars worth of tools sit idle because of the weather. Also, no rust problems.
Len
The amount of dust that would have to be in air to cause an explosion would be so thick you wouldn't be able to stand being in the shop. If the air quality was ever that bad any spark would set it off, the brushes makeing contact with a drill motor could set it off. To make that amount of dust you wouldn't be able to create those conditions with a random orbital sander, a tablesaw couldn't create that much dust. I have no fear of an explosion from dust, and my woodstove. Now if I was useing a spray gun putting on a combustable finish I would be worried, but not from any finish that I brushed on. Woodshops have been heated by woodstove for as long as there has been woodshops, as a mater of fact when I was at my uncles shop helping him 40+yrs ago he had a pot bellied stove in his cabinet shop and it was glowing cherry red no explosion.
Len, do you have to clean the unit often? I would think that any unit like that might require a lot of maintenance. I have a through the wall AC unit and built a prefilter for it so I would not clog the coil.
BRuce
I use an EPA high efficiency, cast iron woodstove in my home, and there is a fair bit of work involved. Cutting and splitting wood, and then stacking and storing it. While burning it, you need to monitor the heat of the flue occaisonally, and then clean out ash every week or so. Burning wood is not like using a furnace.
That being said, I love burning wood for heat. There is something natural about it. I love the feel of the heat, and the look of the flame. It's also a great way to use up scraps and off cuts. Even having a small stack of wood in my my living room is nice.
