Change out the blade or sharpen? Most any good quality blade should be able to take at least one and sometimes more sharpenings before it needs replacing. Your Diablo blade should be able to be sharpened. I've had a Freud LU85R011 blade for years and there is enough carbide on it to take, IMO, 3 to 4 sharpenings before I'll need to replace it.
assuming you mean when do you know the blades getting dull.....
1 feel - after enough experience, you just 'know' when the saw is starting to just start to struggle..
2 burning - when you start to see burning on the cut...
3 tear-out - compare the tear-out when you first install the blade and compare over time...
The list hhh gave is what I look for to know when it's time to resharpen/change blades.
The best blade for you depends....A Hi-ATB grind combined with a higher tooth count will give the cleanest cut with the least tearout if all else is equal, but will also wear a little faster than other grinds that don't cut as cleanly. If you want very clean splinter free cuts for hardwoods, I'd look to a Hi-ATB blade like the Infinity 010-080/010-060, Forrest Duraline/WWI, Freud LU80, or CMT 210.080.10 (a blade like that can also double as an outstanding plywood blade in your TS). If you cut a lot of pressure treated, teak, mequite, MDF, or other hard abrasive materials, a triple chip grind (TCG) might be a good choice. A standard ATB or ATB/R grind offers a compromise between those two grinds...Infinity 010-280, Forrest Chopmaster, Freud LU85.
  • Who's Online   1 Member, 0 Anonymous, 57 Guests (See full list)
