conleya Posted November 25, 2012 Report Posted November 25, 2012 I am looking to make my first Festool purchase and am looking for some advice. I need to get a new sander to work on some end grain cutting boards I am making for Christmas presents. I am looking at the Festool RO 125 and a Midi Dust extractor kit. I am just a hobyist, but want to by a quality tool that will last me a long time, and I like how all of the Festools work together as a system. Does the Festool RO 125 and Midi Dust extractor seem like a good fit? Is there an advantage to going with a larger Dust Extractor? Eventually I plan to add a Festool 1400 Router and TS and want to make sure the Dust Extractor I buy will meet my needs long term. Thanks for any advice. Quote
dodgeram99 Posted November 25, 2012 Report Posted November 25, 2012 I have the RO 125 sander. Great sander, does the job in better then any of my other sander ever could. You mentioned the Midi dust extractor. I thought long and hard on witch one to buy. And what helped me get the festool 48 was. I knew I would buy other festool equipment. And I knew this one would handed any tool I bought. I also didn't want to look back and say I should have bought the 48. So if you can afford the 48 get it. Quote
JerrySats Posted November 25, 2012 Report Posted November 25, 2012 Since you plan on getting more tools I would suggest you get at least the 26. Both the track saw and router make a lot of bigger shaving then just dust like a sander would make . I don't know if the suction is higher on the bigger vac but one things for sure you wont find yourself emptying bags as much with the bigger vac . You're going to love the sander and tracksaw . Regards Jerry Quote
croessler Posted November 26, 2012 Report Posted November 26, 2012 The vacs use the same motor; I believe the major difference to be holding capacity of the vac. Quote
dodgeram99 Posted November 26, 2012 Report Posted November 26, 2012 croessler you are correct. The mini and minding can't use the boon arm. And the 26 tips over sometimes from it. Quote
conleya Posted November 26, 2012 Author Report Posted November 26, 2012 Thanks for the great advice, I think I will wait until I can afford the 48, I would hate to buy a smaller size and be constantly regretting not waiting and buying the bigger size. I will probably still go ahead with the RO 125 though. Has anyone used this sander with a shop vac? Does it work well enough to get me by until I can afford the CT48? Quote
Bobby Slack Posted November 26, 2012 Report Posted November 26, 2012 Rotex is a great sander, I have two 125. Now I wish I would have invested in a 150 ... too late now. On the dust extraction, I would recommend to go big so you can use the reusable bags. Quote
dodgeram99 Posted November 26, 2012 Report Posted November 26, 2012 I have used in with a shop vac. The shop vac does a good job at collecting most of the dust. Quote
justsomeguy Posted November 27, 2012 Report Posted November 27, 2012 The vacs use the same motor; I believe the major difference to be holding capacity of the vac. The Mini and Midi use the same motor. The 26, 36 and 48 all use the same motor(but different from the Mini/midi). Long term you're probably better off with a 26. Quote
conleya Posted November 29, 2012 Author Report Posted November 29, 2012 I just got my RO 125. I don't know how I ever lived with out it. I only had time tonight to use it for about 10 minutes, but my forearms are already exhausted. I can't believe the power this sander has. I am sanding some end grain cutting boards, and the RO 125 with a hard sanding pad and some Rubin P50 is doing an amazing job. I had been sanding on them forever with my old cheap random orbit sander and not getting anywhere. 10 minutes with the Festool RO 125 and they are almost perfect. For now I am just using a shop-vac for dust extraction, but plan to get a CT 36 or 48 soon. Thanks again everyone for the recommendations, I couldn't be happier! Quote
PaulMarcel Posted November 29, 2012 Report Posted November 29, 2012 You might want to get the hard pad for the RO-125; it doesn't give like the standard pad does and makes it easier to get flat when working with agressive grits like P50. Also helps avoid dubbing corners. Quote
