So, I have a decision to make. I don't like using the table saw I have, but it is bearable. If I work hard enough, I can get pretty decent cuts. The one thing I like about it is the heavy cast iron top. This top, compared to saws in its category now make it seem like a premium saw.
We have a 6" benchtop jointer that extremely difficult to get square faces/edges on long pieces. I was thinking that since I have my TS55, I can use that in conjunction with my table saw for the time being and invest in a nice jointer. Hoping something in the 8" range.
Is it worth getting a jointer over the table saw first?
What's wrong with your table saw? If you like the cast iron top, maybe you could buy an after-market fence for much less than a new saw.
Is there an aftermarket fence that will fit on an "angle iron" runner? There is angle iron on both sides of the table that the screw style fence is attached to.
Or is that included steel tube used to replace all that angle iron?
If I can find a fence to fit this, this might work. I also need to fix some wobble in my blade. It wobbles about 1/32" to 1/16" if I just spin it with my hand, and I can see it as the blade starts up. There are small saw marks on the side of my stock, is this because of that? Any ideas how to fix blade wobble in a direct drive style saw?
Yikes. That's sounds like a bad arbor. Not sure if it's worth fixing if it's a saw you already hate. Sounds like you might be throwing good money after bad here...
Would recommend trying to fix it? I read an article on woodgears.ca about grinding the arbor and flange perfectly flat to reduce blade wobble. I was thinking about trying this. I guess it's worth a shot.
  • Who's Online   1 Member, 0 Anonymous, 57 Guests (See full list)
