Earlex 5000 Motor Bearings??
I know the Earlex 5000 system is a popular unit for us hobby woodworkers. I've had mine for about 4 years and have sprayed probably about 15 gallons of finish through it. Mostly waterbase but some shellac.
Lately, I've noticed the motor having a different pitch and I think it sounds like the bearings are starting to go in the unit.
Wondering if anyone else has had similar issues?
Lucas
Possibly the brushes in the motor need replacing?
If you have a local vacuum cleaner repair shop they may be able to fix it. They are just little shop vac motors. Even the larger ones are central vac motors.
Don
I have had luck by carefully dis-assembling and using bearing lube, clean up all the accumulated dirt on the fan blades that throw off the balance.
Thanks for the replies. Yes it does have a filter on the bottom that I clean frequently.
I will probably try dis-assembling the unit and see it there's any build up of debris and if the brushes are worn. Otherwise, it may be time to upgrade!!
  • 26,009 Total Members
  • Joseph b Newest Member ·
