jimbob91577 Posted September 12, 2011 Report Share Posted September 12, 2011 I'm making a cabinet for my grandparent's recently remodeled bathroom. It is a fairly simple design and will have 2 'craftsman' style doors. The cabinet itself measures 22" wide by 24" tall by 8" deep. It will have these hinges from Home Depot. This is my first time making a cabinet. I've attached a 'Sketch-up' picture of what the cabinet will look like - but my question is, how big do I make the stiles & rails for the doors? In my sketch-up, I mocked them up at 1.5" wide. I'm not sure that is thick enough to be visually pleasing. Also, I'm not sure if I should make the bottom rail wider than the top rail. I have tentatively changed my drawing to make the stiles 2" thick this way I am sure to have enough stock to set the hinges in - but before I start cutting lumber, I thought I'd ask the community. Thanks for your help.BathroomCabinet.pdf Quote Link to comment Share on other sites More sharing options...
dwacker Posted September 12, 2011 Report Share Posted September 12, 2011 2.25 wide is fairly standard. Don Quote Link to comment Share on other sites More sharing options...
jimbob91577 Posted September 12, 2011 Author Report Share Posted September 12, 2011 Also - here are 3 more styles for the doors that I was considering Quote Link to comment Share on other sites More sharing options...
jimbob91577 Posted September 12, 2011 Author Report Share Posted September 12, 2011 Thanks Don, I did a mock-up of that and I like it better than the 1.5" stiles & rails. Quote Link to comment Share on other sites More sharing options...
Beechwood Chip Posted September 12, 2011 Report Share Posted September 12, 2011 Try one in sketchup with 1.5" stiles and 2.25 rails. Quote Link to comment Share on other sites More sharing options...
Bobby Slack Posted September 12, 2011 Report Share Posted September 12, 2011 I like using at lest 3" stiles and rails remember you need to attach hinges to it (European ones if that is what you are using.) You could also play with this. A friend of mine made his outside stiles and lower rails 3" and the top rail and inside stile 21/2" and looked very cool. Quote Link to comment Share on other sites More sharing options...
dwacker Posted September 12, 2011 Report Share Posted September 12, 2011 Most Euro hinges have 35mm cup almost 1.4" thus why 2.25 is standard. 1.5 is way to narrow. Don Quote Link to comment Share on other sites More sharing options...
duckkisser Posted September 12, 2011 Report Share Posted September 12, 2011 you might want to consider building it to fit the batroom say if it has a large bathtub like wirlpool you might want to make the rails biger to reflect the size of the tub. its not just a cabinet its a room that has to fit together. Quote Link to comment Share on other sites More sharing options...
