Hinges for small boxes
jimmobley
I'm going to make boxes for christmas presents. Going to finally use my dovetail jig. I need some suggestions for hinges for these boxes. Brass butt hinges(need to be mortised) and barrel hinges need to be beveled I know work but I was hoping there were some non mortise hinges that would work also. Box dimensions 14w x 8 deep x 6 tall, Probably 1/2 to 9/16 thick material. Any suggestions would be appreciated.
the knife style of hinge comes to mind, but make it out of wood and use brass rod as the hinge pin. That way it can challenge you while still looking very neat. (and you can use the router to make the indents for the "knife hinge.")
Thanks everyone, I like the idea of no hinge. Might give one a try.
i found this to be the easiest way to make a box with no hinge is to make the hollow cube then go on table saw and cut shallow cuts on all 4 sides.( if you dont cut all the way it keep the lid from rocking on the blade) then i take a sharp blade cut left over wood off and then chisle the cut smooth. then i just put a piece of wood inside the lid chamfer the edge of the inserted wood and it pops right into the bottom section. this way you dont have to worry about lid fiting just right because the lid was cut off of the 4 sides the inside edge of the bottom matches the inside edge of the lid. i have been making lots of boxes lately so if you want to chat give me a holler.
I like to make a recessed lid and put a 2" brass rod through the side of the box, into the lid which serves as a hinge. A bit of CA glue locks the pin in place (on the box side, not on the lid). It would be possible to hide the pin, but I don't mind seeing the end of the brass rod, so I just polish it up and leave it showing. Here is one that I recently finished. In this photo you can just barely make out the hinge pin at the back left of the box.
post-4499-0-02955500-1316858388_thumb.jp
post-4499-0-84812600-1316858606_thumb.jp
post-4499-0-90273200-1316858626_thumb.jp
  • Who's Online   0 Members, 0 Anonymous, 58 Guests (See full list)
    31.2k
    422.5k
    23,791
    datikeg485
    datikeg485
