Water based topcoat from BORG
I would like to use a water based topcoat on top of GF blaze glaze but and want to just pick one up from Home Depot. Any recommendations? I would go with GF Enduro-Var but I would have to order it and I don't want to wait for delivery and I need to get these bookcases out of my shop. They are taking up some serious space!
Lowes has deft WB and HD has minwax poly acrylic. The MW tends to have chunkies so strain it. Never tried the deft WB. MW is what I use for one of my cheapskate customers that buys nothing but black with poly top coats. Have not had to warranty the finish in the last year. Should be fine.
The MW poly it is then. Thanks Don!
Your welcome. You can also try varathane diamond. It test a little better and sprays better. It test better than GF performance and is a little cheaper at a borg store.
I ended up with MW polycrylic, they did not have any varathane diamond. Should I thin the polycrylic at all?
Check the viscosity and match to your sprayer and needle set. I think it says no thinning on the can but 10% should be ok if needed probably not more. If its still to high/thick for your set up warm it up to about 100 degrees, then check it again.
I don't have a sprayer.
Finally finished the bookcases, kind of a hassle.
I used two coats for homemade chalk paint, used #0000 steel wool and furniture wax to smooth out the finish, applied GF glaze effects, then two coats of MW polycrylic (water based), let cure for about a week and then buffed out with more steel wool and wax. I really might have to get a spray gun for future finishing projects. Here is a picture of one of the bookcases, which was actually built before I upgraded my shop, my wife just wanted me to add adjustable shelves, backs and different color of paint.
Thanks Don!
Mike,
I don't think so but honestly I don't know. At this point I am just trying different things with finish.
Thanks Don!
Mike,
You should avoid any wax except as a final step. But it looks like you got it off before you top coated so no foul. If you missed some the finish would not adhere.
  • 26,009 Total Members
  • Joseph b Newest Member ·
