62vetteefp Posted March 26, 2013 Report Posted March 26, 2013 I just replaced my old Delta contractor saw with a cabinet sawstop. First thing I notice is that when I tilt the blade it magically stays within the zero clearance throat plate. When did this happen? On my contractor I had a separate plate with a wide opening because the blade moved sideways in the plate when tilted. Is the unisaw the same way? Are all modern table saws able to do this magic trick? Is this a cabinent saw feature for all cabinet saws? Thanks, Chris Quote
wdwerker Posted March 26, 2013 Report Posted March 26, 2013 It must not be perfectly zero clearance plate. It should have to angle the sides of the opening. But my UniSaws blade just angles the same opening on my zero clearance plate. I have one of those plates with the replaceable wood strip so I just keep an angled cut one for those jobs. Quote
Nyles Posted March 26, 2013 Report Posted March 26, 2013 Id have to afree with wdwerker it must not be quite zero clearance. I just spent a good part of the day making zero clearance inserts for my saw yesterday and I had to make seperate plates for different angles as well as my more common blades. I dont have much experience with cabinet saws as my personal saw is a contractor style saw but if I recall from when I used a cabinet saw in the past we had to insert different zero clearance inserts, Nyles Quote
62vetteefp Posted March 26, 2013 Author Report Posted March 26, 2013 I was just tilting wo power but I did notice that the opening as it came from the factory was just a bit larger than my thin kerf WW II blade. And it makes sense that the kerf at a blade angle has to be larger than at 90 degrees. Anyway my old saw had a 3/8" wide opening in the throat and it used up the whole amount. Things change. Quote
wdwerker Posted March 27, 2013 Report Posted March 27, 2013 A quick fix for zero clearance even with an angled blade is to put a scrap of 1/4" Masonite or MDF over the table saw and tape it down. Then raise the blade up thru it. Keep in mind that the thickness of the sheet might affect the distance of the fence setting on an angled cut, measure a test cut scrap before you ruin a bunch of good stock. I have re used the same piece of MDF for many different rip settings. It also will keep laminate and veneer from slipping underneath the fence. 1 Quote
Eric. Posted March 27, 2013 Report Posted March 27, 2013 That's a good tip, Steve. I made ZCI's for 45*, 30* and 15*, but when I need some other angle I have to resort to the stock plate with the wide opening...I refuse to make 45 different inserts to cover every scenario. I'll try the MDF aux table next time. But the shop made inserts are great because they truly are zero clearance...which makes me breathe much easier when doing those nasty bevel cuts. Quote
62vetteefp Posted April 1, 2013 Author Report Posted April 1, 2013 Eric what/where did you get that blue fence hold down thing? Quote
CessnaPilotBarry Posted April 1, 2013 Report Posted April 1, 2013 A quick fix for zero clearance even with an angled blade is to put a scrap of 1/4" Masonite or MDF over the table saw and tape it down. Great way to keep a sled running, too! A 1/4" floor, and a 3/4" rear fence liner. Slide the fence liner around until it's no longer usable, and keep pushing the kerf together on the floor liner. Quote
Eric. Posted April 1, 2013 Report Posted April 1, 2013 Eric what/where did you get that blue fence hold down thing? Rockler. Be careful with them, though...they have a tendency to kick your aux fence out of square to your table. They should have made the hook part longer. Quote
wdwerker Posted April 2, 2013 Report Posted April 2, 2013 +1 on that Eric! You have to be vigilant about fence squareness, cut squareness and a square cut getting out of square by the time the saw marks are sanded out! Keep checking constantly! Quote
62vetteefp Posted April 3, 2013 Author Report Posted April 3, 2013 Mark had a plywood jig he sat over the fence that used a couple bolts to tighten onto the fence for a stop for cut offs. Do these bolts just run into the fence or Is there some kind of friendly surface to protect the fence? Quote
Byrdie Posted April 4, 2013 Report Posted April 4, 2013 Was that used as a stop or was it really a standoff so that cross cuts on the miter gauge weren't run right up against the fence? (I think the later.) Anyway, it just clamps against the fence because it doesn't need to be tightened down so much that it leaves a mark. You could slip a thin sheet of ply in there as a clamping sheet too if you were worried about marking your fence. Quote
62vetteefp Posted April 4, 2013 Author Report Posted April 4, 2013 I think it acts as both. Thsnks Quote
