TooTightIsBroke Posted April 18, 2013 Report Posted April 18, 2013 Our plane at work has Been giving me some issues, I wondering if you guys might be able to help. First off I will say the planer is the only machine I haven't setup/ maintained so I am pretty unfamiliar with the mechanism of it. The big problem is when feeding wood in, even with a light cut its about all I can do to get the wood in. Once the wood is in, the feeder is very sporadic and the board will frequently stop, needing to be pushed/ pulled the rest of the way through. Is this a pressure bar issue? Seems like that may cause it to be hard to get started if it is not adjusted properly? Also could it be pressing so hard that the feeder slips on the face of the board? I have been using it on some old old old reclaimed oak that is incredibly hard. Could the harness of the wood cause the feeder to not bite as well? Or could the feeder need to be adjusted down? Second issue is the snipe seems worse than I remember, can I minimize the snipe somehow? I don't know our model number but its a 20" helical head, 3 phase unit. In need of advice, I wanna figure this out before I have no choice to but to put an actual project through there. Thanks guys.p Quote
TooTightIsBroke Posted April 18, 2013 Author Report Posted April 18, 2013 I should have made a point to say that the board is not stopping due to tapering away from the feeder, this thing is still cutting when it stops, resulting in some burnt snipey situation that really make my day a lot of fun. Quote
TRBaker Posted April 18, 2013 Report Posted April 18, 2013 First, wipe the bed down good with Mineral Spirits, dry, and apply some paste wax. A lot of times you get resin build-up and it will grab your boards and keep them from feeding. On the snipe issue, try lifting the end of the board as it enters and exits the plane. As soon as the pressure rollers kick in, lift your end a little until you can feel the upward resistance. As the board exits, do the same at the other side. Sometimes these simple things will solve the issue. Quote
Boatworks Today Posted April 18, 2013 Report Posted April 18, 2013 I'd be curious to hear how the board feeds when you plane it twice (without changing the thickness of the cut). Run it through and let it do it's thing, Turn the board end for end then pass it again without lowering the head (making sure to plane the same face of the board). Does the feeder grab the wood, and does it pull it through? Are there any rough marks or indentations from the feeder? If I remember right the feeder is a metal roller with a spiral type pattern? I'm guessing the problem may be: - Pressure adjustment on the feed bar -The cutter head is not parallel (doubtful but flipping the board end for end may help figure this out) - OR the feed table is not level with the planing surface. Could be a combination of the above.. Making sure the table is clean and slick as TR suggested could play into this as well :-) Quote
dwacker Posted April 18, 2013 Report Posted April 18, 2013 The snipe is your clue. As stated clean and wax then wax and after you wax wax some more. Lower the bed rollers all the way down level with the table. Feed a board through the planer. Now re feed the same board. It should feed leaving very slight serrations in the surface. If it does not then tighten the feed roller half a turn on each side and try again. Now feed it again as it exits barely push the board in if it pushes back in real easy tighten the exit feed rollers a half turn. It should take quite abit of pressure to stop the feed. Now take the top off and feed the same board. Watch the pressure bar it should barely rise of course keep your hands out of there while running. While the top is off look at the bottom of each carbide cutter where it meets the head. If there is dust build up use a stiff brush and clean. Helicals loose chip load capacity with pitch. Now you should have no visible snipe and you feed should be perfect. Also make sure you are feeding at the proper rate. The 20 is a four speed make sure you know what sprocket is installed. Helicals have a small chip load capacity so use the low speed sprocket. You should not have to lift the board as it enters or exits. Fywi if this is a commercial shop they should be aware and have a bucket of a product called waxilit. If not contact your tooling manager or dealer. 1 Quote
Trip Posted April 18, 2013 Report Posted April 18, 2013 ==> and after you wax wax some more +1 I like that... Quote
CT Proctor Posted April 18, 2013 Report Posted April 18, 2013 I have a 20" PM planer and was having the same exact problems last summer. Did basically what Particle Board described and I've had no issues with it since. Quote
TooTightIsBroke Posted April 19, 2013 Author Report Posted April 19, 2013 Thanks guys, I will take all that into consideration while I tinker tomorrow, we are a commercial box shop, so this planer is rarely used and not serviced like our other machines, actually I seem to be the only guy doing any machinery tuneup (aside from blade changes). I had to resquare our altendorf slider the other day, making a new knob for our t square on the pmatic, fixed our temperamental pressure pot,a mile of abrasives to change, the list goes on and on, I left for 2 years and returned to find the place in disrepair. They won't even sweep up anymore, ... That reminds me i probably got 4 overflowing drums of sawdust to get rid of. Yeahya Quote
