I have a new a Delta Unisaw L36-352.  I want to build a base for it that will accomplish a couple of things:
  1. Make it mobile
  2. Raise the height to approx 39 to 40 inches.
I'm getting a little bit older and I have a lot of lower back problems and it helps me to have tools and tables a little bit higher for me.  After finding and watching this video from Allan Little (aka Askwoodman), I see I'm not alone.  And I think he's brilliant to have all his tables at 40 inches so.  Don't know what I'm talking about?  You can watch this:
I've got some really sold casters.  CarryMaster AC-300 to use.  Now I'm debating about how to build the base.  Assuming that the weight is not an issue, would you suggest building a torsion box, or maybe just using 2 or even 3 sheets of 3/4 MDF and screwing and gluing it together?  I know a torsion box is really strong and rigid, but it seems like 3 sheets of MDF would be just a rigid.  Am I mistaken?
Any other ideas or suggestions?
Note: I don't want to buy one of the little mobile bases that are for the unisaw.  It won't raise it as much as I want, and they just don't roll that well.
Thanks in advance.
Well, I believe that over the span you are looking at and with the weight of the saw, it will bow with just 3 layers of mdf. I would be inclined to use poplar as the torsion grid and skin with plywood. Probably 3/4".
Are all the casters locking? There is a lot of force placed on the saw when in use. I also have back issues but don't find the short time at the TS a problem, I do have a taller bench and work tables though.
BRuce
BRuce
Thank you for the reply.
I know torsion boxes are really strong.  But, one of their advantages (as I understand it) is strength-to-weight ratio.  In other words, the are lighter than a sold structure yet just as strong.  But, if I don't really care about weight, and I just want easy/strong, then I would think that approx 2.25 *inches* of MDF would be incredibly strong.  I have a work table that I build for my shop where I used 2 layers of MDF for the top (glued and screwed together) and I'm not sure I could bust it with a sledge hammer.  I'm certainly not trying to argue with you.  You may very well be right.  Just throwing it out to people to see if anyone has experience with such things.
And yes; the casters are locking/leveling.  Here is a video from "HalfInchShy" on the casters I have.  I actually got the idea from him.  They are rated to support 330lbs each, so more than enough for my ~660lbs saw and a mobile base.
http://www.zambus.com/product/ac300.php
I think the mdf will be fine. All your force will focused on the corners where the casters are. If you are worried about sagging, glue some ribs in a honey comb pattern under where the casters are mounted.
When I built my bench, I used 3 layers of 3/4" mdf and was going to top that with 3/4" maple and oak strips. The mdf was glued and screwed and after ~ 48 hours, the screws were removed. I then got distracted by life and it was several weeks before I got back into the shop. When I did get back in I found a swayback bench. There was about a 1/2" droop in the bench top. I had to jack the middle, wait about 3 weeks and then add 3 stretchers under the mdf. Is is still flat today but mdf sags under its own weight.
The other poster is correct, the force will be centered at the casters and the feet on the saw. How big is the platform going to be?
BRuce
I'm currently think 78" x 36".  I've never had any problems with my sagging, but it was only 2 layers think and was pretty will support with aprons made of 2x4s.
So, torsion box is the way to go here?
Yea, go torsion box. The MDF will sag no matter how thick it is but a torsion box stays flat and spreads the load. I am planning several new outfeed tables that are also used for assembly work and they will all be plywood torsion boxes with a 1/4 MDF replaceable skin on top.
If the weight of the saw is over the casters, the layers of MDF are just a spacer.  The worse that would happen is compressing the MDF, which won't happen with 600lbs/4.  If you are making a bigger platform on the casters with the saw somewhere on the platform, then you'd need to go for a torsion box.
You'll love those casters.  Excellent for leveling and really don't move.  Be sure to bolt your saw down to the MDF sheets that are glued/screwed then bolted to the casters.  The only negative with those casters, which isn't a problem for my uses (assembly table and LT-18 bandsaw) is that they take time to expose/retract the wheel.  They are more made for semi-permanent installations.
  • Who's Online   1 Member, 0 Anonymous, 35 Guests (See full list)
