baok Posted May 8, 2013 Report Posted May 8, 2013 I've been making some 2" wide dadoes. I defined the edges with a saw and finished up the bottoms with a router plane. In between those steps I tried bashing out most of the waste with the widest chisel I have. This mostly works but occasionally will get away from me and I'll dig out a but too much. Is there a better way to go about this? Multiple saw cuts perhaps? Quote
wilburpan Posted May 8, 2013 Report Posted May 8, 2013 Two options that I can think of: 1. Hammer less hard. It's not a race. 2. Don't worry about it. If there are divots at the bottom of the dado, you won't see them unless they are at the ends, and it won't compromise the strength of the joint unless you've done a real butcher job, which I know you didn't. 1 Quote
RenaissanceWW Posted May 8, 2013 Report Posted May 8, 2013 Usually I go with the multiple saw cuts approach just to "loosen" up the meat in between the walls. Really at 2" wide you would only need 2 or 3 saw cuts to break it up and now you need much less effort to chop out the waste. Just make sure you have some safety glasses on as those little pieces will rocket all over the place and mostly back into your face. The saw cuts act as a relief cut so any grain run out you encounter doesn't have a chance to get started and dive too deep. 1 Quote
ChetlovesMer Posted May 8, 2013 Report Posted May 8, 2013 I would suggest a router. I don't know the details of how you are set up, but consider building a variable width dado jig for your router. You can use it in a whole bunch of projects. If you build the jig you won't regret it. Quote
