elimelech12 Posted September 25, 2010 Report Share Posted September 25, 2010 I was going to help my brother with built-ins around a nice new bay window he put in, but when I went today to help him measure out and figure out materials I notice he was his heating unit along the entire length of the wall! Is there anyway around this or will he need to have it relocated? Quote Link to comment Share on other sites More sharing options...
elimelech12 Posted September 26, 2010 Author Report Share Posted September 26, 2010 anyone???? Quote Link to comment Share on other sites More sharing options...
PaulMarcel Posted September 26, 2010 Report Share Posted September 26, 2010 So is this a small radiant heat (I think called a baseboard heater)? As in, is it something down by the baseboard, maybe 5" high, 3" deep? If so, see if he can remove that first; regardless of any code, you wouldn't want to put a built-in over it. If it's removed, you won't get the heating benefit so you might want to instead incorporate it into the toe-kick area of the built-in. Depending on how the toe-kick is built, you might be able to do it. Just check the heater manufacturer's specs for clearances around the unit. If the built-in's toe-kick is the usual 3" and the heater would need, say, a 6" toe-kick, just build it up and install the built-in higher. Assuming that is possible. If it isn't a baseboard heater, it would be helpful for a link to the unit or photo of what's currently there. Quote Link to comment Share on other sites More sharing options...
elimelech12 Posted September 26, 2010 Author Report Share Posted September 26, 2010 yeh it is baseboard heating...but you definitely wouldn't recommend build above it? Quote Link to comment Share on other sites More sharing options...
Vic Posted September 26, 2010 Report Share Posted September 26, 2010 Like Paul said, check the manufacturer specs for clearance on the baseboards. The last thing you want to do is have that new built-in be kindling for a house fire. Quote Link to comment Share on other sites More sharing options...
iSawitFirst Posted September 27, 2010 Report Share Posted September 27, 2010 if you built over the heater and it doesn't catch on fire (which it will), consider the temp differential that your wood will be subjected, ie. major shrinking and expanding. I agree that moving the heat source is the way to go. Quote Link to comment Share on other sites More sharing options...
