1 car garage set up shop price
I use a pellet stove in my shop and love it.  Easy to install and cheap to run.
I considered a wood stove, since I burn wood for heat in my home. Decided against it because of the initial start up cost.
I set up a used pellet stove in the shop and was under 500 with the pipe.  Added a thirty dollar thermostat and was done.
I use pellets in my house as well.  Just got tired of doing the firewood each year.
ill probably get an electric or gas wall mounted heater don't have to be big just big enough to keep me semi warm......if I do pottery as well maybe ill just do pottery in the winter and heat the space that way with my kiln.  or maybe ill do blacksmithing in the winter.
Wow! I paid 4000 for a cast iron stove, chimney and pipe (including install with a hole cut in the roof). Though I must say that I bought a top of line stove, with a double walled chimney, all installed by a pro. It paid itself off in two years of oil savings.
Pellet stove can be run thru the wall.  They also don't require the clearance from the wall that the wood stove does.
However, no power means no work...lol
As i mentioned in a separate shop heater post, i picked up a dayton 90k infrared heater propane for $50. I have never used one and i know that most savy home energy people do not recommend the indoor ventless but for the cost of entry and the cost of use, i'm going to give it a shot! I hope i can fire it up soon before it gets mega hot in NJ to determine if its going to get me through the winter. If i hadnt found the IR heater i would have gotten a ceiling hanger propane exterior vented type like the mr. Heater or other brands.
This heater looks good for a one car garage.
http://www.leevalley.com/en/wood/page.aspx?cat=1,43456,43465&p=70821
Those look great!  Will have to look into one of those for my reloading room!
I bought a different heater from lee valley before these were available, and it works pretty well. I may replace it with one for the models I mentioned above. But for 60 dollars, it's hard to complain about its good performance.
http://www.leevalley.com/en/wood/page.aspx?p=44590&cat=1,43456,43465,44590
found a ton of furnaces and heaters on Craig's list.
A lot depends on how much you can do yourself and what local codes allow you to do. Here, I can take out a permit and do the work myself and have it inspected so everything is on the up and up. Some cities do not allow you to do work such as electrical etc.
Insulation is a BIG PLUS, DO IT! We are in a desert, cold in the winter (but not like you!) and hot in the summer. Insulation, high roof line and over sized ridge vents keeps the shop at least 10 deg cooler in the summer and then in the winter, closing the vents keep it at least 10 deg warmer in the winter. You WILL need a heater of some sort if you plan to work in the winter.
3K for a single garage and a lot of DIY, should be more than enough for infrastructure. Not so much if you need to contract out a lot of it.
Are you planning on black iron pipe for air? It is inexpensive and will hold up. Run drip legs with a drain at the end of a run to let water get trapped and disposed of without interfering with air tools etc.
Do plan on running 220v to the shop, with a sub panel there. That makes the whole job much easier and much more flexable in configuration. One large run from the electric box to the shop then you can get whatever you want from the sub panel.
Regardless of how big you make your shop, it is NEVER enough! LOL! When we poured the slab for my shop, before the walls were even up, I walked the slab with the wife and after pointing out where things were going, I looked at her and told her, "it isn't big enough" LOL!
never enough but right now im cramed into a corner of basement with only scroll and band saw. everthing else is small hand carving tools.  my lathe is in the garage and to turn i have to drag it out in the drive way. thanks for the advice cal
  • 3 weeks later...
went over with my brother to check out garage its packed with junk and part of roof leaked so ill have to climb up and replace it.  all the stuff that got wet has to be tossed. but i did get some measurements and i think i will wall in the porch for lumber project storage plus ill put dust collector/compressor out there and feed pipes in a window to remove the noise. scrounging around my house i found 4 lighting pannels, a mile of electrical wire :) pvc for the air compressor, tar paper and shingles, and my brother has some cabinets he has just siting on his garage floor i might buy from him to make a work counter out off.  plus half a gallon of light green paint that i might use for the cabinets, a gallon of white paint for the walls,
my game plan is this fall
ill take the roof off then before it gets cold
pull the furing strip walls off the garage fill with insulation and the put up ply or other cheap pannels
put in celing pannels
install small heater
put in a sub pannel and stretch electricity
hang lights
then i can tape off where i want my machines and plan out my duct work move in my lathe and other machines and furniture.
then ill start building in dust collection little by little as i get new machines.
then i can start adding little things like shelves, tool racks as well as shop furniture
  • 26,012 Total Members
  • JAR Newest Member ·
