Andrew Pritchard Posted July 12, 2013 Report Posted July 12, 2013 So this is my first (almost) completed project. I had some off cuts of some cherry I'm using on a blanket chest for my wife. As my brother and father's birthdays are coming up, I figured I'd use some of those off cuts along with some birch to make them some presents. The picture below is mid way through the project where I wanted to test that it was actually going to work. I thought I'd try a little test. I sanded one all the way up to 220 grit. They came out pretty smooth, and was happy with that. The second one, I sanded with an 80 grit to make sure the surfaces were flush, then used a super sharpened utility blade as a cabinet scraper. That made the second one even smoother than the first - so smooth I refinished the first one. For small items a utility blade works very well as a scraper and they are really inexpensive. So far I've put two coats of 2lb cut shellac on them, with a very light sanding between the coats. I might put a third coat of shellac on, and then finish it with two, maybe three coats of polyurethane. I'll post pictures of them before I wrap and send them. Overall I'm pretty happy with them, although there are a couple of very fine gaps in some of the joints where one of the surfaces wasn't quite square. I don't suppose it'll be an issue long term as they aren't structural, but time will tell. Of course, England's humidity levels are significantly different from Nova Scotia so it'll be interesting to see how they cope! Quote
..Kev Posted July 12, 2013 Report Posted July 12, 2013 As long as you're giving away presents, you could send one my way Nicely done! I'm sure your father and brother will be happy with them! Quote
