The left handed drill bits are there to grab the screw and hopefully back it out.  Normally, you want to use oil or cutting fluid to drill a hole to keep from dulling and burning up the bit through friction/heat.  This case is different.  You want the PB Master Blaster to get in and soak through the threads at least overnight. Then, take some solvent like lacquer thinner and a Q Tip and clean the end of the screw.  You WANT friction here between the bit and the end of the screw.  Drill slowly with the left hand drill bit because you want it to grab the screw - you're not so interested in cutting a hole though it may.  You want friction because you want the drill bit to grab the screw and back it out.  It may just slowly drill a hole.  If it does, repeat with the next larger sized bit.
Heating - heat expands things - in this case, metal.  If the above doesn't work, you could heat the surrounding area around the screw but not the screw.  Think about it....If you heat the screw it gets tighter in the hole through expansion.  Heat the surrounding area to a "little too warm to the touch" temperature and then go again with the LH drill bit - slowly.  Maybe a combination of all of it will release the screw.
Try everything first without heat.  It may just back out.  If that doesn't work, apply the heat but not directly to the screw.  Think of a shooting target with rings.  The screw is the bulls eye.  Don't heat the bulls eye.  Heat the surrounding area to expand it and hopefully increase the surrounding area a few thousandths making the screw have less friction in its hole.
Now....having said all that....it's sometimes easier to take a piece to a machine shop and ask them to get it out.  They may not charge you but $10 or $15 if it comes out quickly.  Dirty Harry said, "A man's gotta know his limitations".  In my case, I used the PB Blaster, LH drill bits, and THEN snapped off an easy out in the hole.  :o  :blink:  :o  :blink: Like someone said, they're brittle and HARD and once that snapped, I know I was done for. If the LH drill bit doesn't work, you may think about a machine shop.
I tried two different screw extractor kits.  Both had left handed drill bits to use with matched extractor bits.  None of the drill bits got any "bite" into the shaft of the snapped off screw.  They would just spin without making a hole.  Either the screw shaft is some sort of super-hardened steel, or I'm doing something wrong.  I triple checked that I was spinning the bit in the right direction - when I looked at the spinning drill bit the "barber shop pole" was moving away from the tip.
Keep in mind that this is a very small diameter screw.  The shaft diameter is under 1/8".I've only used screw extractors on small screws, and I've always had the same result - I just can't drill into the screw shaft.
I now have to decide between:
  • do without a jointer
  • buy another jointer
  • take this jointer to a machine shop and ask them to extract the screw
  • figure out some other way to extract the screw
I'm leaning towards the machine shop approach, but that involves finding a machine shop, and getting the jointer to it.  Work is getting crazy, so this will be on the back burner for a while.
Did you try the easy out?
Machine shop will probably dill a bit oversize, tap, and put in a helicoil..  If you're "tool savy", it's not a difficult process..
At this point, I'd grind it out with a Dremel or die grinder, take the machine apart, and drill and tap a new hole near that one if the screw needs to be that small.  Just epoxy the old hole shut and paint over it, if the way it looked mattered.
That's a good idea.  My Dremel (actually, a Harbor Freight rotary tool) was actually making good progress on the screw, where the drill bits were just spinning their wheels.
I tried this and this.
I consider myself pretty "tool savvy".  I've drilled and tapped goles in metalworking shop in high school, and in a few DIY projects since then.  My problem is that I can't drill out the screw.  It just laughs at my drill bits.  But maybe I can grind it out, then drill and tap.
Thanks for the ideas and encouragement.
Damn that's tempting.  I've been wanting a 16" jointer.
Hey...I picked that one but they have a few others with helical heads for ONLY 2 or 3 thousand! :) Go getcha some!
  • Who's Online   1 Member, 0 Anonymous, 35 Guests (See full list)
