The first time took me about a half hour, because I had to experiment and figure out which grits of wet-or-dry to use.  I had sent off a couple of sets to be sharpened and they weren't back yet.  That left me with the set on the machine.  Running the old heart pine asked for fairly frequent sharpening because some of the boards sides were dirty.
I have a Lee Valley jointer knife sharpening guide, but had never used it.  The second time, I had the half sheets of sandpaper left out that I had used the first time to dry, because they weren't ruined, so I could grab one without delay.
9x12 surface plate.  Piece of Formica for the screw adjuster of the guide to ride on.  Hand finish on 8000 grit Norton waterstone to shaving hair on arm, flatten water stone on plate when finished
Take blades out, sharpen, reinstall.   Freud knives sharpened pretty quickly.  I started to use lapping film, but decided to use regular wet-or-dry to see if it would work.  220, 320,400,600,1500   8,000 waterstone by hand to finish.  I don't use PSA on a surface plate.  Wet-or-dry will stay in place just fine will only water under it.  I put the surface plate on a Sterilite container lid to catch all the slop.  It's heavy enough that it doesn't move.
I was surpised that the high speed steel cut that quickly.  One blade had the largest knick, and I went back to 100 for that one.
To install jointer knives, I take out any springs and adjustment pusher screws and do it by feel.  I use a small straight piece of wood. In this case a 3/8 by 1/2 inch piece of Boxwood that I had laying around.  Tighten the screws at the ends and back off a hair until it will hold the knife in place but still allow you to move it. That might sound impossible, but it's really easy.  Swing the cutterhead back and forth until the edge hits the strip of wood.  If too high you can push it down with the wooden strip.  If it takes a shaving, move to an uncut part of the strip.  Tighten the end screws when it's right, and then tighten the rest on that bar. Takes longer to type it out than do it.  Only a minute or two to re-install the knives.
Without getting in a hurry, but having everything laid out to work with, start to back up and running, 16 minutes.  I think it will take less time once I do it a few times.  This time took a bit extra because I had to get a sheet of 100 out and cut it in two.  You only need a half sheet for 1/2 of the plate, because the adjuster screw takes up the other half.
I'll not bother to send any off again unless they are pretty beat up.
link to honing guide:    http://www.leevalley.com/en/Wood/page.aspx?p=33002&cat=1,43072,43078&ap=1
I sharpen my joiner and planer knives on my Tormec. Jig was expensive but it gets blades much sharper than sending them out.
I am impressed at your speed! Takes me a lot longer but I am a bit of a perfectionist and use a magnifying headset to get the blades just right.
I use a lope too, to make sure any knicks are gone- a reversed telescope eyepiece.  These knives are Freud, and I thought high speed steel.  I was surprised at how fast they were cut by the sandpaper-almost as if they were O1.  The honing jig works much like one for chisels and plane irons.  You can feel when it's time to move to the next grit, just like if it was a 3/4" chisel. Stay there for a few passes to make sure, and check.  I did each grit at a little bit of a different advance angle, so I could see when the last scratches were gone.  Changing sandpaper was instant, and only took a short amount of time on each.
What a timely thread for me, I just ordered two sets of knives for my 6" jointer. I had thought of sending the old ones out for sharpening but replacements were very reasonable at about $24 a set so I will make scrapers or some such thing out of the old blades, they were beat and way beyond dull, I know they were easily older than 20 years as I have had the machine that long but as I only recently started using it, who knows how much older the blades are. I hope I have as much luck setting mine as you have with yours.
I set mine in about 15 minutes using these super easy to make jigs. I got the idea from FWW. Just be careful that you don't scratch your jointer bed with the magnets, they are very strong and hard to move around.
http://www.finewoodworking.com/workshop/video/jointer-knife-setting-jig.aspx
It takes less than a minute to install a knife with a straight strip of wood without getting in a hurry-actually, probably more like 30 seconds.  I think I explained it above.  A small strip of hard wood lets you feel when the edge is rubbing it as you swing the head back and forth. I don't even keep one just for the job-just pick up the best thing that's handy, or at worst run one.  You place the strip over the end bolts on the outfeed table, and swing the cutter head back and forth.  It's hard to push the knife down too far.  If for some reason it does go too low, pull it up with your fingertips, and swing and feel some more.  Once you do it a few times, it doesn't take long at all.
 I had magnet jigs that I bought years ago, and gave to a friend who could never develop the feel for doing it like I do.  I also have all manner of dial indicators and stands that these days I only use for setting up a big planer.
You can push the knife down with the wood without damaging the edge.  Tighten the end bolts until you feel them get snug and then back off just enough to hold it in place, but allow you to move it. Don't think what fraction of a turn.  It's a feel thing.  Only the slightest little bit.  If the knife falls down it's too loose.  Can't move it-too tight.   Rock the head back and forth until you get it just right, tighten the end bolts, then tighten the others.
I'm sure it took longer to read this than to install a knife.
  • Who's Online   1 Member, 0 Anonymous, 35 Guests (See full list)
