chrisphr Posted August 11, 2013 Report Posted August 11, 2013 I bought it used, Jet jointer. Spent about 2 hours replacing and adjusting the knives a few weekends back. Finally ready to use it on a "experience building" project, some wall hanging cabinets for the garage. Since this is a practice project, using cheap wood "white wood" from hardware store, don't know species, probably some type of pine. So after giving it a go today, have three questions I was hoping the experts on this site might be able to educate me on. 1. I know jointers and planers create a lot of saw dust but the dust tends to be pretty corse. So, didn't bother hooking up the shop vac, planned to just sweep up the mess when done. Problem is, instead of blowing the waiste onto the floor, it just stayed in the machine, packing in until I had to stop my work (after about two boards) and clean it out. Is the only way to get the dust to vacate the machine with a commercial dust collector? 2. I don't have a good feel for how much pressure to put on the wood as I slide it through the machine, right now using very light pressure, just enough to hold on and push it through. That sound about right? 3. Finished jointed boards have a very slight wave pattern parallel to the cutter knives (perpendicular to the direction of feed). Will easily sand smooth with a couple passes of random orbital sander. While easily fixed, are these waves common from a jointer? Or are they a sign that something is wrong with the tool or tecnique, or is it just a peculiarity of soft wood (in this case, presumably pine). New to milling wood, so any thoughts on this will be great. Also, next week will be sending the same boards through a dewalt 13" planer I've never used before, if there are any tips you think might help me out before I start that I would appreciate that as well! Thanks in advance! 1 Quote
mikem Posted August 11, 2013 Report Posted August 11, 2013 1. I always use my DC on both the planer and jointer. Both these machines create a lot of shavings and I have noticed not using it can alter the quality of each pass. 2. Light pressure is best. I have found it effective to keep the pressure on the outfeed side of the jointer. 3. Those are often referred to as milling marks. I have sanded it out with no issues. Others have used a #4 hand plane or cabinet scraper to remove those as well. 1 Quote
Tom King Posted August 11, 2013 Report Posted August 11, 2013 I used a jointer for many years with just an open topped cardboard box that had a cut out to fit around the outfeed hole. A dust collector is of course many times better. You only need enough pressure to keep it down securely on the outfeed table. When it stays on the outfeed table for the whole length of board, it's straight. Slow your feed rate down, or install the blades better to reduce milling marks. I'd try to find someone who can show you in person how to use one. I'd be glad to show you, but Cornelius is a long way from me. I live on Lake Gaston. 1 Quote
chrisphr Posted August 11, 2013 Author Report Posted August 11, 2013 Thanks for the posts, this is helpful. Sounds like (1) dust collector is better than no dust collector. (2) I have the right idea with the pressure, but there is a little "feel" to learn to get it down perfect. (3) The milling marks (thanks for giving me the right vocabulary for this) are common, but can be mitigated by slowing down and/or adjusting the knives. Good thought on having someone show me, I'll keep an eye out for someone local. Maybe a dust collector will make for a nice bday gift, have to work on the wife for that! :-) Quote
pghmyn Posted August 12, 2013 Report Posted August 12, 2013 How big of an opening is there for your dust chute? I have never had a problem with the chips clogging up in any machine I've used. Although, if you get a dust collector it will almost inevitably be better. Reason why you want to hold it down just enough, just on the outfeed table (when enough board has passed through), is because think about that soft wood you are working with. If you are milling a face, and it is warped, and you push down hard enough to "push" the warp out, it will run through flat. However, when you release pressure it will go right back to being warped. Let the machine do the work Any pictures of the machine? Quote
chrisphr Posted August 12, 2013 Author Report Posted August 12, 2013 Sorry about the photo quality, all the tools have been packed away for the evening so the car can get parked. You can still see the dust port from this angle. Let me know what you see. Quote
Tom King Posted August 12, 2013 Report Posted August 12, 2013 The black square part with the round hole is an adaptor for a dust collector. If you aren't using a collector, take that off, but keep up with it. I'm not familiar with that machine, but I'm assuming it has a sheet metal formed chute behind the adaptor. A cardboard box that is tall enough to go to the top of the square chute will work until you can do better. Just cut out the end to go just below the built in chute. I used one like that for probably 30 years. 1 Quote
pghmyn Posted August 12, 2013 Report Posted August 12, 2013 Just as Tom said. Remove that black shroud and you should be golden. I think in the second picture you can see the chute aiming upwards. Or maybe I am imaginative, and think I see it Quote
chrisphr Posted August 12, 2013 Author Report Posted August 12, 2013 Sure, the old "remove the obstruction" solution! So simple, I am now embarrassed :-). Reminds me of third grade math, greater than or less than (which way does the alligator's mouth point?). Seriously, I think that will fix the problem. That said, the earlier two posts got me researching dust collectors and now I am starting to get tool envy again... Thanks for your help, I am going to try that next weekend. Quote
chrisphr Posted August 12, 2013 Author Report Posted August 12, 2013 Just as Tom said. Remove that black shroud and you should be golden. I think in the second picture you can see the chute aiming upwards. Or maybe I am imaginative, and think I see it Thankfully not pointing up (the lighting is creating an illusion), if it were, I would have to retire from this hobby due to embarrassment. :-) Quote
..Kev Posted August 12, 2013 Report Posted August 12, 2013 No need to be embarrassed! We all make mistakes, the art is in recovery! I remember my first post here and caught crap for a misspelled word... In your case, it's not really a mistake as you haven't used this piece of equipment before. Chin up, motor on! Quote
Tom King Posted August 12, 2013 Report Posted August 12, 2013 Being in N.C., check out the Woodtek (store brand) collectors from Woodworkers Supply. They are near Burlington, right on I85. Picking one up will save the sizeable shipping cost. If you can pass as a "Pro", there is a decent discount. I was in there buying something and the salesman asked, "You're a pro aren't you?" I said, "Yes sir, since 1973", and he signed me up for the pro discount (on everything they sell) without any more questions. I'm using their 3hp unit that I think cost a little less than $600. They work fine. My portable jointer is a 6" Woodtek. Quote
chrisphr Posted August 12, 2013 Author Report Posted August 12, 2013 Act like a Pro? No problem. Just walk in looking the part and act like you own the place. Been doing that to great success my entire career... :-) Seriously, thanks for the tip, been looking for specialty woodworking retailers in NC Quote
