I'm pretty sure this is user error but I am frustrated not being able to lock in the fence on my Powermatic 8" jointer. I can get it square but when I push wood against it, it moves about 25 thousands. The result is my board not being square. Does anyone have a tip or suggestion on how to keep it locked where I want it? Thanks :)
I've never used the PM-60 or any other jointer with this particular fence mechanism, so the obvious caveats apply...
I've taken a look at the manual and have the basic gist...
To clarify, with the fence at 90deg, resting against the stop and the 'lock' handle engaged, you can press against the fence and get 0.025 deflection?  Since the stop is set at 90deg,  I'm assuming you are deflecting to 89.975?  Does the lock-handle tighten-up prior to 'bottoming-out', so the locking mechanism torques-out prior to running-out of room to tighten?  i.e., you can't tighten the locking mechanism further, even if you had more room to tighten?  Since the mechanism is gear-driven, how much 'play' is there in the gearing?
Check this part on that schematic.
21.............PJ882-121 ...............Stop Block.............................................................................................
Looking at the way it works, I'm betting on someone trying to adjust it with the wheel without unlocking it.
Your stop should not be needed to hold the fence at the desired position. Stops are only a quick reference point so that the fence can be returned to the same position. If the lock is slipping causing the fence to go out of square you will have to tighten the lock. If you cant tell in the manual how to tight the lock call PM support and they will step you through it.
  • Who's Online   2 Members, 0 Anonymous, 56 Guests (See full list)
