Router bit doesn't fit and today's safety lesson
I've got a porter cable router model 690 that I picked up used. Strange thing, 1/4 bits won't fit in the collet without force, and clearly also require force to remove, even with the collet completely removed.
Think this is a bad collet that needs to be replaced? Or is there something I can do to make it work?
Today's safety lesson is to wear gloves when handling router bits. I learned the hard way. :-(
Thanks in advance for your thoughts!
Sucks that you are experiencing this as well, but at least I now know that I am not the only one that has to fight his router to get it to work. Just bought new collet on amazon less than $12, if that solves the problem will let you know.
Every router I've ever owned does this like Woodsap said a light tap on the collet or the bit rectifies the problem I've always just figured dust or something wedges the bit causing it to freeze in the collet I wouldn't worry to bad about it.
Some do, some don't . I have some Porter Cable 1/4" and 1/2" collets that do that and others that don't ( I have 8 of the #690 ) I think it is just the variations in the springiness of the metal.
I think mine might be exceptionally sticky. I struggled with it for more than an hour, giving it a lot more than a light tap. Finally gave up (after lacerating three of my fingers) and decided to use one of my other routers (bosche) that doesn't have this problem. I was hoping to use two routers for the project but one will work, albeit slowly...
Get a new collet for it if you need it.  The new ones ( in the last 25 years) are self-releasing.  You loosen the nut with the wrench, but then continue turning the nut until it gets to another sticking point, and a little further turn with a wrench breaks it completely free easily.  Check to see if this is how yours works.  If it doesn't, get a new one off ebay.
To me, after dealing with having to knock them out, the self-releasing collet was the greatest woodworking invention ever.  The first one I bought came with a new router.  I immediately tossed all the old ones, and ordered new collets.
