Thanks Pete, that is what I am leaning towards right now. I have an email out to one supplier. I am a little concerned because my motor arbor size is slightly larger than what he had listed on his website. I am waiting on his response before I proceed.
Kick around on this site long enough and you hear some of the same things.  For this problem, Steve will often point people toward the bearings and run out. That's because he's right! On older saws that have wear, bearings are often the problem and they're not a hard or expensive fix.  Causes of loss of power and vibration are two different subjects. They can be interrelated but assuming there are no blade problems, vibration is basically caused by bearing wear, belt inaccuracies, or pulley defects. Any of these detract power but to cure vibration, go to these first and go to the easiest first - bearing check.  If they're tight, try a link belt. If vibration persists, it may be a casting or balance problem with the pulley or it could be slightly eccentric.
Thanks Tim. Based on the fact that the runout of the bearing/inner flange was less than a thou. I ordered the pulleys and belt. I received them, but have not opened them yet as I have another two projects going! As I get a little closer and cleaner in the shop, I will give a full review. Thanks for the info. I really hope that this cures the issue, and I really think it will, since most of the vibration comes from the motor bouncing on the belt when running and yes that does come from the motor resting on the belt and creating a flat or the overlapping of the cords in the belt, I am not sure which.
When I am finished, I may devise a system to store the saw with the weight of the saw taken up off of the belt...
On the craftsman that I used to use It was a simple matter just to lift the weight of the motor up and take the belt Off of the pulley when I was not using it....
After swapping out the pulleys and belts yesterday I completely understand what you are saying. I wasn't sure as this is my first contractor saw. I wonder if I should store the link belt in the same fashion?
First report, awesome!!! I really must make a video or something, day and night..
Good deal!  The link belt won't be as prone to develop memory like a regular V belt but if it's a simple thing to remove it from over your pulley, do it and just make it a part of your start up when you go in the shop. Wow...it's 46 degrees this morning in coastal SC and feels great!!
Yes, I am loving the cooler temps here too.. high of 86 the other day :-P
  • Who's Online   2 Members, 0 Anonymous, 56 Guests (See full list)
