chopnhack Posted September 23, 2013 Report Posted September 23, 2013 Has anyone sprung the coin for machined pulleys on their contractor saw? Have you noticed any improvements? I have an older Jet that was well cared for, but would like to see it be a little smoother in operation. I did change the belt when I first got it, but I didn't see any change. I also made sure the pulleys were aligned with each other. I didn't want to spend the money on a link belt before first looking into the pulleys. Any comments would be appreciated! Thanks. Quote
ColinF Posted September 24, 2013 Report Posted September 24, 2013 Well, I can see if you get a lighter (aluminum) pulley it might improve power output, I don't know if it works on saws, it works on cars? Quote
chopnhack Posted September 24, 2013 Author Report Posted September 24, 2013 True, works on cars, probably would work on the saw, but power or power transfer per se isn't what I am looking for. Will installing a new machined pulley make the saw smoother? Thanks. Quote
wdwerker Posted September 24, 2013 Report Posted September 24, 2013 Check the arbor for run out or worn out bearings. It's a triple problem, belt and alignment, pulleys and arbor/ bearings. Any one or all 3 can cause your problems. 2 Quote
TRBaker Posted September 24, 2013 Report Posted September 24, 2013 It could also be a blade problem, added to what Steve said. Quote
Tom King Posted September 24, 2013 Report Posted September 24, 2013 Was the replacement belt a fractional horsepower belt, or one from an auto parts store? I'm betting probably not the pulley, unless maybe it's a diecast aluminum one. Quote
tim0625 Posted September 24, 2013 Report Posted September 24, 2013 But yes....a link belt will make it smoother, hence quieter and with aluminum pulleys you'll save some power. Like Steve said though, bearings are always suspect in older saws. Quote
AceHoleInOne Posted September 24, 2013 Report Posted September 24, 2013 Maybe a little off topic, but could be of interest to those regarding link belts. Put a link belt on my band-saw settled everything down and was running smooth. Had been re-sawing wide maple and birch boards. Noticed the saw was having a little trouble keeping up. Put the old V belt back on and notice better saw performance. -Ace- Quote
dwacker Posted September 24, 2013 Report Posted September 24, 2013 You can put perfume on before you leave the gym without taking a shower, but you still stink. 1 Quote
T-astragal Posted September 24, 2013 Report Posted September 24, 2013 You can put perfume on before you leave the gym without taking a shower, but you still stink. You lost me. What's a gym? Steve 1 Quote
ColinF Posted September 24, 2013 Report Posted September 24, 2013 You lost me. What's a gym? Steve Gym?, what's a gym? (Pronounced gime)-Homer Simpson Quote
chopnhack Posted September 25, 2013 Author Report Posted September 25, 2013 Was the replacement belt a fractional horsepower belt, or one from an auto parts store? I'm betting probably not the pulley, unless maybe it's a diecast aluminum one. The old belt had a lobe in it from sitting for so long... probably like the existing one now that it has been two years! To answer your question, the belt was from an auto parts store, but it was nearly identical, if anything it was a hair shorter. Why? How much play in the arbor is considered acceptable? Quote
T-astragal Posted September 25, 2013 Report Posted September 25, 2013 [quote name="chopnhack" post="101496" timestamp="1380069734" How much play in the arbor is considered acceptable? Quote
chopnhack Posted September 26, 2013 Author Report Posted September 26, 2013 None in a perfect world! So are we talking like 1 thousandth or less? Quote
Tom King Posted September 26, 2013 Report Posted September 26, 2013 The old belt had a lobe in it from sitting for so long... probably like the existing one now that it has been two years! To answer your question, the belt was from an auto parts store, but it was nearly identical, if anything it was a hair shorter. Why? How much play in the arbor is considered acceptable? All automotive belts will add a bunch of vibration. They all have a big enough bump where they are joined-even Gates. I found this out the hard way years ago. After the original belt wore out, I bought a belt from an auto parts store. I had a friend machine the steel pulley, and it didn't change a thing. After that, he told me to get a fractional horsepower belt, which smoothed it right out. Order a good fractional horsepower belt online. I've had one on my Powermatic contractors saw for over 20 years. The link belt didn't work because between the range of adjustment, and stretch in the belt, the motor would either not go up high enough for a deep cut, or flop over backwards for a low cut with just the change of one link. The ideal length for the link belt did not exist for this saw. It's a cast iron top one, model 64 I think, that I bought new in 1975. I'll see if I can find a link for a good fractional hp belt. http://www.vbeltsupply.com/ecommerce/fractional-wrapped-belts Supposedly for 1hp and below, but the saw I'm talking about has always run a 2 hp TEFC motor running 230V. Goodyear makes a pretty good variety of them. You need to know width, and length, and then find a good one online, unless you live in or near a large city. 1 Quote
ColinF Posted September 26, 2013 Report Posted September 26, 2013 All automotive belts will add a bunch of vibration. They all have a big enough bump where they are joined-even Gates. I found this out the hard way years ago. After the original belt wore out, I bought a belt from an auto parts store. I had a friend machine the steel pulley, and it didn't change a thing. After that, he told me to get a fractional horsepower belt, which smoothed it right out. Order a good fractional horsepower belt online. I've had one on my Powermatic contractors saw for over 20 years. The link belt didn't work because between the range of adjustment, and stretch in the belt, the motor would either not go up high enough for a deep cut, or flop over backwards for a low cut with just the change of one link. The ideal length for the link belt did not exist for this saw. It's a cast iron top one, model 64 I think, that I bought new in 1975. I'll see if I can find a link for a good fractional hp belt. http://www.vbeltsupply.com/ecommerce/fractional-wrapped-belts Supposedly for 1hp and below, but the saw I'm talking about has always run a 2 hp TEFC motor running 230V. Goodyear makes a pretty good variety of them. You need to know width, and length, and then find a good one online, unless you live in or near a large city.so are link belts not a viable option? I've got a new bandsaw and I was thinking about putting a link belt on it but I honestly wasn't sure if it was worth it. Quote
dwacker Posted September 26, 2013 Report Posted September 26, 2013 You can buy FHP belts at any decent auto parts stores. Quote
Tom King Posted September 27, 2013 Report Posted September 27, 2013 The only FHP belts at auto parts stores here are the cheap ones, which still have a big lump where they're put together. I just bought one a few weeks ago for a riding mower deck. It was a Gates, but nothing like the Goodyear one on the table saw I was talking about. They come in several different designs and qualities. Some are especially designed for smooth running around small pulleys. I only knew about them back then (before the internet) because the machinist told me about running them on his metal-working equipment, and he ordered one for me from some machinist supply. I think a lot of people run the link belts, but it just wouldn't work on this particular saw. It might work fine on yours. Quote
chopnhack Posted September 27, 2013 Author Report Posted September 27, 2013 Thanks for the info and the link. I will have to consider this, but I am pretty sure the saw is 1.5 hp. Quote
PeteJr Posted September 29, 2013 Report Posted September 29, 2013 I added machined pulleys and a link belt to my 1985 craftsman table saw and also installed a high quality thin kerf blade. The quality of cut improved significantly however the fence became the limiting issue in terms of repeatability and setup. 1 Quote
chopnhack Posted September 29, 2013 Author Report Posted September 29, 2013 I added machined pulleys and a link belt to my 1985 craftsman table saw and also installed a high quality thin kerf blade. The quality of cut improved significantly however the fence became the limiting issue in terms of repeatability and setup. Hi Pete. I wonder how much of the improvement was attributed to the thin kerf blade? Lower powered saws, mine included (figure anything under 2 HP) IMHO require a thin kerf blade. Have you ever had any slippage under heavy load/deep cutting? Thanks for your input. Quote
PeteJr Posted September 30, 2013 Report Posted September 30, 2013 Hi Pete. I wonder how much of the improvement was attributed to the thin kerf blade? Lower powered saws, mine included (figure anything under 2 HP) IMHO require a thin kerf blade. Have you ever had any slippage under heavy load/deep cutting? Thanks for your input. I use thin kerf and full kerf blades. I notice more with the full kerf that the motor will slow if I'm cutting stock thicker than 1 inch and the feed rate is too fast. Quote
chopnhack Posted October 1, 2013 Author Report Posted October 1, 2013 I use thin kerf and full kerf blades. I notice more with the full kerf that the motor will slow if I'm cutting stock thicker than 1 inch and the feed rate is too fast. If the motor is slowing, at least you know the belt is still transferring power! Thanks Quote
chopnhack Posted October 22, 2013 Author Report Posted October 22, 2013 Ok, reporting in from the shop: It is hot as anything down here! Aside from my melting, I got some data from my t.s. The inner arbor flange measured out to 0.0003 runout while spinning free hand. With belt on using motor to run its an erratic reading, needle swinging wildly in a range of about 7 thousanths. So what do you folks think of that? Get the machined pulleys and link belt or fractional hp belt as was mentioned? Quote
