Advice on a finishing problem. (Maple, Tung Oil and Minwax Paste Wax)
Hello,
Recently I was volun-told by my wife to build a closest system with some built in drawers and hanging rods.
Using 3/4 Maple veneer ply from Home Depot for the inset area and solid maple for the perimeter.
I have the small chest of drawers built and finished with three coats of Tung Oil (100% tung oil from Rockler ). I waited 24 hours between each coat.
Initial sanding 120then 220.
: First coat thinned 50/50 with Mineral spirits
: Second straight from the container applied with 600grit sandpaper.
: Third just a clean rag.
For the drawer fronts, I let these dry for 24 hours then rubbed on a coat of Minwax paste wax and buffed it off.  Most of the surface looks great however I have these random dull spots in areas.  As these sit, the problem seems to be getting more noticeable.    I can't tell if my problem is something like the wax didn't take or if it's the tung oil process.
The texture feels the same to the touch but one could certainly tell in a rake light.
Attached are two images which sort of show what I'm taking about.
Anyone have any ideas where I may have gone wrong ?  Any better yet, any suggestions on how to correct the problem?
post-14932-0-68215100-1388020755_thumb.j
post-14932-0-71988200-1388020769_thumb.j
Tongue oil sometimes takes weeks for the excess to ooze out of the wood and off gas.  My first guess it that you didn't wait long enough before applying the wax and you're now getting build up under the wax.
Byrdie's right...24 hours isn't even close to adequate for drying time for oil.  I have a little cabinet I built last March that I finished with BLO...9 months ago...and it STILL smells like oil.  It can take months for oil to cure.  And if you try to apply wax over uncured oil, something not good is probably gonna happen.
I personally like how an oil finish looks on a lot of woods (maple isn't really one of them, though...turns yellow...at least with BLO), but be aware that your tung oil finish will offer almost zero protection to your project.  If it's something that's going to be used constantly and subjected to daily interaction (which this sounds like it will be), I'd consider a more durable top coat.
Uggh.. Thanks for the info.  It sounds like my only option is to strip the wax with some mineral spirits and let these things sit for a while.
  • 1 month later...
So what is the solution to this problem?  I have run into the same issue.  I used thinned tung oil for the first two coats on a stool seat, one each day, then a few coats of wiping poly and I have dull spots.  Should I just wait a few weeks to apply more finish or do I have to strip all the finish off and have a do over?
Spunjin, I would recommend sanding by hand lightly with 220.  That will even out the dull spots and remove some of the poly.  Then wipe with a tack cloth to remove the sanding dust.  Wait a week and observe the surface.  If it reappears, you're still weeping oil.  In which case, I would repeat the sanding.  Even though it says 100% tung oil, it does have driers in it.  But, it will still take weeks for it to dry out.  You need to make sure the oil is dry before applying any other top coat.
Thanks, Tim.  I sanded lightly with 600 last night to get an even dull surface then applied another coat of poly thinking it would even out.  This morning it still had dull spots.  I'll sand again with a lower grit and set it aside.  At least I'll be able to get working on other projects now.
I use tung oil for canoe paddles, then put a true spar varnish over the blade area.   I have actually got in the habit of putting the tung oil on in the Fall (before my garage/finishing area goes below freezing), and letting the tung oil cure over the winter before putting the Epifanes on before use in the Spring.  A bit extreme, however I am always surprised at being able to smell a hint of curing tung oil 2-3 months later.   Not sure that would be enough to make visible discoloring, but it is indicative of just how long the process can take,
