I just replaced my blade with a  1/2" woodslicer. I can't seem to get a true running blade despite the saw is brand new and the stock 3/4" blade I replaced ran true.
Symptom: blade runs to and fro by sighting the back edge by eye what looks like about 1/16" (into stock,out of stock....)
Things I checked (double checked):
Centered blade by eye on lower wheel
I centered the blade on top wheel and at full tension it's tracking in the middle of the top wheel as sighted in window. No tracking adjustment far left or right seemed to make an improvement.
Set blade tension looser and tighter with no improvement.
This happens despite top and bottom guide rollers being completely backed off or adjusted properly.
Spun blade by hand, and there are no rubbing noises.
My first thought was the wheels are not coplanar but that doesn't make sense since the blade I just took off had no problems running true.
am I missing something simple?
Did the new blade get kinked or twisted during install?  Only other thing I can think of is if the weld on the blade was straight?  If you lay the blade flat on the floor does it actually lay flat or is it lifting somewhere?
First rule out the blade. Take it off the saw and find the weld. Lay about a foot of the blade across the corner of your table or table saw with the teeth down. It will be bowed up off the table if the weld is crooked, this is common. If its straight you dont have enough tension. Now here is the good and bad. You can't tension the flutter out of a 1/2 blade on a 14-18" bandsaw running full speed so you have to guess somewhat. If you use the flutter method with a small wheeled saw you WILL over tension the blade. Small wheel saws will always have flutter with a properly tensioned blade running at full speed. So instead of buying a tension gauge move your belt to the slow speed and tension your blade until the flutter is gone, then move your belt back. The flutter will return but the tension will be right. The short version is I think you have a bad blade.
