I have only used the big one but the price is different enough to make me think it has a smaller motor as well. The bigger stone should have a longer working life before replacement. The Tormek does a great job but it is slow, which keeps you from heating up and ruining the steel.
I've not looked at a T3 is quite some time... So from memory:
Mechanically:
1) T7 has a continuous duty motor. I forget the T3's duty-cycle, but I think it can only be run for 30mins without an off-cycle.
2) T7 has a heaver-duty frame.
3) T7 can apply almost arbitrary tool/wheel pressure without stalling, T3 will stall if you go too hard. Note: I'm not suggesting that applying a great deal of pressure on the tool is a good thing, it's just a surrogate for motor torque.
Functionally:
1) T7's hollow-grind is quite shallow, there is wide-spread agreement that it can be treated as a flat grind...
2) The T3's hollow-grind has a tighter radius, so the use of a secondary bevel is important to back-stop the edge. Note: The benefit of T7s shallow-grind is universally accepted. However, debate continues on shallow-radius hollow-grinds and the relationship to secondary bevels.
3) Many of the high-quality aftermarket wheels are only made for the T7.
4) T7's shallow-grind is a benefit to turners, not as much to cabinet makers who tend to hone a secondary anyway.
5) T7's shallow-grind is a benefit for sharpening planer/jointer/etc long knives where a secondary bevel would be hard to hone.
6) T7 is more applicable for any application where secondary bevels are difficult to hone*.
Cost:
1) T7 is almost twice the T3's price
2) T7 wheels are also almost twice the price of T3 wheels
3) T7 wheels last longer
Summary:
T7 would last you a lifetime - not so sure about the T3.
*Note: There are some who maintain that secondary bevels can be directly honed on a T3 -- while this is technically true, the secondary's radius would leave the edge susceptible to rapid breakdown.
  • Who's Online   2 Members, 0 Anonymous, 56 Guests (See full list)
