Henjam48 Posted October 26, 2010 Report Posted October 26, 2010 Hi Peeps from Oz.. I am an ex Muso who now works for a Timber (Lumber) retailer. I am proud to say that in 2 years I have attempted more projects than my boss who's been in the industry for over 30 years. I recently scored a free table saw, that needed a little work. I sought advice from the great god youtube and stumbled across the Wood Whisperer. The table saw sings, and I am much more confident thanks to Marc. Sir.. Your advice on clamps has been invaluable.. But please accept the metric system. We have ten fingers, and ten toes, and the Cm has 10 mm, the Dm has 10 cem, the M has ten Dm etc..etc.. easy! No fractions. While I wait for you to catch up I will use my trusty Nokia Phone converter. Cheers James Quote
Bobby Slack Posted October 26, 2010 Report Posted October 26, 2010 James; Greetings from California. I grew up in Argentina (born in Pennsylvania) and of course I think in metric. All my drawings are done in metric. Most of my tape measurements are done in metric. I only use the imperial system to discuss things with my customers. You are right, the metric system makes a lot more sense, specially using system 32 for cabinets, all jigs and hardware are built for that system, why fight it? By the way, the reason for 32mm is because at the time, the manufacturers of multi-boring machines could not space these spindles closer than 32mm. Again ... greetings and go metric. Quote
woodwhisperer Posted October 26, 2010 Report Posted October 26, 2010 I think you might be asking the wrong entity for the metric switch. lol I'm fully on board. In my previous career, I worked in a lab where metric was all we used. It makes sense and it simplifies things so you are preaching to the choir. Unfortunately, I won't be able to switch to metric until the rest of my country switches to metric. Quote
Bobby Slack Posted October 26, 2010 Report Posted October 26, 2010 Marc ... you made me laugh. OK Let's all jump of the cliff at the same time I think you might be asking the wrong entity for the metric switch. lol I'm fully on board. In my previous career, I worked in a lab where metric was all we used. It makes sense and it simplifies things so you are preaching to the choir. Unfortunately, I won't be able to switch to metric until the rest of my country switches to metric. Quote
Pete Bennett Posted October 26, 2010 Report Posted October 26, 2010 Hi Mark how long have you got? If the States does go metric however, make sure every one knows which system you are going to adopt. In the UK when it happened more than thirty years ago now, it was clearly stated that the millimetre was the preferred unit in what was then called the SI system. I still have my booklet supplied by the 'Metrication Board' which states and I quote 'As the SI system is a Coherent system the preferred unit of base measurement will be the millimetre'. However, from that day to this all kids in school are taught using the Centimetre as the base unit?? We also had for more than twenty years in the timber trade a peculiar system whereby you purchased so many metres of 4"x2" or 3"x1" or 6"x3" Even now you will hear most folks asking for an 8'x4'x 9mm plywood sheet or any similar thickness. It's a great world out there ain't it. Pete Quote
Beechwood Chip Posted October 26, 2010 Report Posted October 26, 2010 I think we should all switch to relative dimensioning. To communicate sizes, we should use common objects as references. "For the sides, I'm going to use birch plywood that's as thick as my pinky." Of course it's not exact - each person uses their own dimensions depending on what stock they have, what looks right to them, etc. I challenge Marc to do an entire video without using English or metric measurements. I bet it would be easier than you think. If you take the Halloween router bowl video and replace "8/4" with "pretty thick", I think you'd have it. Quote
Bobby Slack Posted October 26, 2010 Report Posted October 26, 2010 There are three countries who have not embraced the metric system: Liberia, Myanmar and United States. I just heard this ... pathetic. Loved your link. Quote
woodwhisperer Posted October 26, 2010 Report Posted October 26, 2010 haha I like that idea, lol. I'll protest imperial by using nothing but relative dimensions. Great idea!!! Quote
simocco Posted October 27, 2010 Report Posted October 27, 2010 Hi Mark how long have you got? If the States does go metric however, make sure every one knows which system you are going to adopt. In the UK when it happened more than thirty years ago now, it was clearly stated that the millimetre was the preferred unit in what was then called the SI system. I still have my booklet supplied by the 'Metrication Board' which states and I quote 'As the SI system is a Coherent system the preferred unit of base measurement will be the millimetre'. However, from that day to this all kids in school are taught using the Centimetre as the base unit?? We also had for more than twenty years in the timber trade a peculiar system whereby you purchased so many metres of 4"x2" or 3"x1" or 6"x3" Even now you will hear most folks asking for an 8'x4'x 9mm plywood sheet or any similar thickness. It's a great world out there ain't it. Pete excelent post! i do laugh when using mixed units! Quote
simocco Posted October 27, 2010 Report Posted October 27, 2010 Hi Peeps from Oz.. I am an ex Muso who now works for a Timber (Lumber) retailer. I am proud to say that in 2 years I have attempted more projects than my boss who's been in the industry for over 30 years. I recently scored a free table saw, that needed a little work. I sought advice from the great god youtube and stumbled across the Wood Whisperer. The table saw sings, and I am much more confident thanks to Marc. Sir.. Your advice on clamps has been invaluable.. But please accept the metric system. We have ten fingers, and ten toes, and the Cm has 10 mm, the Dm has 10 cem, the M has ten Dm etc..etc.. easy! No fractions. While I wait for you to catch up I will use my trusty Nokia Phone converter. Cheers James Hi, from a fellow metric man, in the UK! and yes timber not lumber lol! nice job on the tablesaw! i need one myself! Quote
Pete Bennett Posted October 27, 2010 Report Posted October 27, 2010 excelent post! i do laugh when using mixed units! Cheers mate. But what about pounds and ounces kilos and grams I know I'm eleven stone nine, but I think I'm around 74 Kilos eh, maybe. And don't forget the American gallon is not quite the same thing as a UK gallon. Now we get into computers and guess what? no one speaks the same language (sorry we're incompatible you're on a Mac and I'm on Unix don't forget the Windows duffers eh!) Quote
simocco Posted October 27, 2010 Report Posted October 27, 2010 Cheers mate. But what about pounds and ounces kilos and grams I know I'm eleven stone nine, but I think I'm around 74 Kilos eh, maybe. And don't forget the American gallon is not quite the same thing as a UK gallon. Now we get into computers and guess what? no one speaks the same language (sorry we're incompatible you're on a Mac and I'm on Unix don't forget the Windows duffers eh!) hey why not throw politics and religion into the mix and be done! or perhaps just leave it that we all agree on one thing...wood is good! Quote
Lawrence Brown Posted October 29, 2010 Report Posted October 29, 2010 So Marc should trace his hand onto paper, and then we can each order one from the Wood Whisperer shop, cut it out, and use Marc Measurements, or MM for short! "The front panel of this drawer will be 1 MM pinky thick..." And of course that gives the added bonus of confusing anyone that doesn't know the secret and thinks we are talking millimeters. They'll end up with dollhouse furniture! Quote
Guest Trace Posted October 29, 2010 Report Posted October 29, 2010 Hey, you guys left out angular measurment. Degrees, Radians and Gradients. Teaching and tutoring math where all of the different kinds of designations are used, the unit is not as necessary as knowing how to use the required math. I have a very inexpensive hand held calculator that will do all of the conversions. I think it cost about $20.00. I think it takes about 10 mineuts to memorize the conversions from inches to centimetere or milimeters. 2.54 centimeters = 1 inch, 25.4 milimeters = 1 inch, 39.37 inches = 1 meter. It may seem confusing at first, but with a very small bit of practice, it becomes second nature. If you already think in terms of mumerical units, it is really easy. Quote
Bobby Slack Posted November 1, 2010 Report Posted November 1, 2010 ... and football (futbol for me because I grew up in Argentina). Now we start a whole new thing. hey why not throw politics and religion into the mix and be done! or perhaps just leave it that we all agree on one thing...wood is good! Quote
